Old Fogey 2 In Foam
by nickatredbox | March 9, 2013 | (0) Posted in Projects
Due to the apparent poor performance of my Coroplast Fogey I have built a foam board one to see if it works better :) It Flys :) Fogey and Piper Cub
All finished
AUW 732 Grams
1000mAh Zippy Compact
Landing gear
All rubber bands ect ready to fly
My custom power pod
2210N 1000Kv Brushless motor
Weight: 45g
Shaft: 3mm
Spec.
GWS9050 @3S
Max Amp: 11.2A
RPM/Min: 8700
Thrust: 740g
APC9x3.8 @2S
Max Amp: 6.5A
RPM/Min: 6260
Thrust: 405g
My Thrust Tests with a GWS 10X4.7 slow fly and a 2200mAh 3 cell
3.7 A      45 Watts     303 Grams
7.3 A      86 Watts     480 Grams
9.5 A      111 Watts    550 Grams
13.1 A    150 Watts    655 Grams
HobbyKing 12A BlueSeries Brushless Speed Controller
Spec.
Cont. Current: 12A
Burst Current: 16A/10sec
Battery: 2-4 Cell Lipo / 5-12 Cell Ni-XX
SBEC: 5V/ 1A Output
Weight: 10g
Spec.
Capacity: 1000mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 25C Constant / 35C Burst
Weight: 82g
Dimensions: 76x15x34mm
Balance Plug: JST-XH
Discharge Plug: XT60
No Comments Yet
Be the first to leave one!
Old Fogey 2 In Foam
