The FPV Stick Project
This is my FPV Stick. I am currently waiting till my birthday in May to get a new 900mhz 500mw fpv system, for short range FPV in the neighborhood. It has a 30 inch wing and the weight is currently unknown.
The length is 30 inches.
The horizontal stab is 9 inches.
The vertical stab is 5 inches.
I have sanded down the leading edge for minimal drag, I also did the same to the vertical stab and horizontal stab.
It will be powered by a Turnigy 2204 -14T with a 6 inch prop.
The control surfaces are operated by three 9 gram servos. I am also waiting on a spectrum full range receiver and sat antenna
It is flown by an 800 mah 3 cell battery I taped nuts to the front for ballast due to lack of FPV equipment.
The wing span is 30 inches (the ruler looks bent due to the camera lens).
