this is my scratch built glow stick (as I call it ) made with holm oak (main fuselage)
balsa(horizontal and vertical stabilizer covered with monokte) ,foamboard (main wing) and ply (motor mount)
the electronics are:
servos:http://www.hobbyking.com/hobbyking/store/__3715__Hobby_King_S0361_3_6g_45kg_12sec_Micro_Servo.html
reciever:http://www.hobbyking.com/hobbyking/store/__14352__FrSky_V8R4_II_2_4Ghz_4CH_Receiver.html
battery:http://www.hobbyking.com/hobbyking/store/__18557__Turnigy_1000mAh_1S_20C_Lipoly_Single_Cell_.html
booster (for the battery)http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11784
engine http://coxengines.ca/cox-.049-engine-babe-bee.html
the vertical and horizontal stabilizers are just balsa wood covered with monokote
The wing is like the armin wing by experimental airlines you can check how to make it here:http://www.youtube.com/watch?v=karr67ZYho4&feature=plcp
but i made it without paper on both sides and added some polyhedral
it is very very pitchy but some expo should be more than enough and the polyhedral helps a lot when turning it can do loops aldouh i dont recomend it becasue the engine might not get enough fluel and it will eventually shot down
if you want the dimentions please ask for it on the comments
-Flitetest_mexico
sorry if i didn't answered your question
Saludos de Ecuador
saludos
could you post the dimensions or plans for the vertical and horizontal stabilizers and for the wing?
Thanks
