The Flite Test Beginner Series is brought to you by Horizon Hobby.
Episode 4: Launching and Landing
There are some fundamental things that you can do to prepare yourself for a successful R/C flying experience and they all start with properly learning how to launch and land you're airplane.
Preflight Check
The Preflight Check is a list of essential tasks that increase your chances of a successful flight.
Check Range
Each radio manufacturer has different methods. Refer to your manual for instructions. If a manual is not available you can search R/C forums for the information you need.
Check Batteries
Use a battery checker to make sure you’re starting with a fully charged battery.
Label with Contact Info
Check CG
Check the manufacturer’s recommendations for the Center of Gravity for your specific plane. Quite often the CG is between 25%-30% from the leading edge of the wing.
Check out these videos for more information:
Check Propeller Direction
Make sure your prop is facing the right direction and it is spinning the right way.
Check out this video for more information:
Check Control Surfaces
Make sure your control surfaces are moving freely and moving in the right direction.
Check Flight Area
Plan your pattern before taking off. It’s easy to get excited and take off quickly. Look up and visualize wide turns and make yourself aware of obstructions, wind and sunlight.
Plan Your Landing
Always have a plan to land before taking off. It helps to visualize your approach and touchdown.
Check Wind
It’s important to always take-off and land into the wind. If the wind is too strong don’t attempt to fly.
Taxi
Practice “driving” your plane. It’s good to understand how your plane responds to your input on the ground.
Ground Launch
Launch into the wind
Launch and land straight away
Don't climb too steep (the plane will roll or stall)
Hand Launching
Have a friend throw it for you
Don't launch in a way that will chop your fingers
Throw level
Running glide test
Landing
Always Land into the wind
Don't stall (landing faster is better than stalling?)
Practice (maybe touch and go?)
Flaring (Check out this video Landing and Flaring)
Touch down before the plane passes you.
Hard surface landing
Belly landing
If you know someone that may benefit from this article, share it with them. Help us make this hobby friendly and approachable!
We would like to thank Horizon Hobby for sponsoring this Beginner Series! Let us know what you think of this content and let Horizon Hobby know as well! You can find out more about Horizon Hobby HERE.
HorizonHobby-BeginnerSeries
I haven't flown in over 40 yrs. and most is new for me again.
Keep it up guys.
I am not sure if this is the right place to ask if not just let me know where and i will fix it.
I always wanted an F-22.
The problem i am having is that i have bought the (3 Pack Swappable Speed Build Kit) and managed to crash all of 2 of them.
I think the most problem i had was that where i live it is always windy.
Do you think this will be a good plan to start with (not really start) the F-22 because have a bit more of power or i should go with something more slow like (FT Old Speedster) or is another one?
Thanks a lot.
Any tips for a very new flying wing pilot?
Boy do I wish I'd found you guys just a little sooner.
