The Flite Test Beginner Series is brought to you by Horizon Hobby.
Understanding your R/C control system is very important. The better you understand your components, the better you’ll be able to troubleshoot problems down the road.
Communication link:
You talk to the transmitter (TX)
Transmitter talks to the receiver (RX)
Receiver talks to the servos and ESC’s
Servos moves your control surfaces
The ESC drives the motor
Radio Control Transmitter (TX)
The transmitter uses radio signals to remotely control the aircraft.
The control sticks (gimbals) or switches on the transmitter are each assigned to a channel.
The number of channels are how many functions or features can be used to control things on the aircraft.
Different brand transmitters have different encryption and channel assignments. Usually they are not cross compatible.
Radio Control Receiver (RX)
Receives the encoded radio signal from the TX and converts it to instructions for each component connected to the receiver.
Each channel can control a separate function such as a servo, speed controller, lights, landing gear, etc.
Servos
Servos comes in many different sizes and shapes, but they have a common purpose: to move control surfaces.
Servos are usually classified by weight.
9 gram servos are used in most park flyers and are the most common.
Servos connect directly to the receiver (RX).
Electronic Speed Control (ESC)
The ESC controls the speed of the motor as commanded by the receiver (RX).
The main battery plugs into the ESC.
Most ESCs have a built in BEC (Battery Elimination Circuit) that provides power to the receiver (RX) and servos.
If you know someone that may benefit from this article, share it with them. Help us make this hobby friendly and approachable!
We would like to thank Horizon Hobby for sponsoring this Beginner Series! Let us know what you think of this content and let Horizon Hobby know as well! You can find out more about Horizon Hobby HERE.
HorizonHobby-BeginnerSeries
R/C Control System
I'm about to start my own scratch build so knowing a bit more about the electronics gives me more confidence for my attempt.
But there are fat and grey, and we call them Rhinos!
:P
Regarding the radio I would like to know if you can recommend other radios with more capabilities for the future, I really want to go ahead in this cool hobby and use the resources wisely. What do you think about the Turnigy 9XR or the 9X?
By the way, you guys are awesome, I'm impressed with your professionalism, Thousand,Thanks for everything.
Im a big RC Car guy and really wanna get into planes and heli's but the air radios are so much more complicated then the ground ones.
Keep up the good work, your amazing
amazing job guys, keep up the good work!!
Just getting started in electric rc airplanes. Over the past years I have bought several RTF electric RC airplanes only to crash them. Most of them were the older RC radio airplanes (ex. RTC Wingo). As such, I have never flown an electric RC airplane successfully and now I think I need to give this hobby another try.
Thank you for the Beginner's Series. With luck I hope to get started soon.
Put a fresh charged pack in & the RX goes nuts SINGS & FLASHES like crazy until I unplug ,switch off theTX & start over . Voltage check on charger says full .
Another point , I am old school & used to switching so have fitted switching between BAT & RX by breaking into power ( RED. or ORANGE ) as getting to unplug gear in these smaller & more fragile airframes is a struggle ,
Waiting for the kit now for BABY BLENDER Looks like a lot of fun
