The Flite Test Beginner Series is brought to you by Horizon Hobby.
Episode 2: Basic Aerodynamics
We know you’re excited to get in the air. But we also know you’ll have more fun if we can help keep you up there. In this video and article we will go over some basic aerodynamics. We’ll focus on the information that’ll help you grasp the art of flying quickly.
The Basic Plane Parts
Fuselage - The main body. Everything connects to this.
The Vertical Stabilizer - Keeps the plane’s yaw movement stable.
The Horizontal Stabilizer - Keeps the plane’s pitch movement stable.
The Wing - Generates lift.
Airfoils
The shape of a wing or propeller blade as seen in cross-section.
The difference between the top and bottom of the airfoil determines the amount of lift the wing will have. Symmetrical, Semi-Symmetrical and under-cambered are popular airfoils due to their unique characteristics.
Symmetrical - Very low drag which means it’s fast and more agile. It’s good for aerobatics. However, it’s not a high lift design.
Semi-Symmetrical - Has a high camber, producing a good lift-to-drag ratio.
Flat Bottom - Not very common.
Under-Cambered - Produces the most lift but it’s not the best choice for performance.
Lift
There are two principle on how a wing generates lift:
1. Bernoulli's Principle
As the velocity of a fluid (air) increases, its pressure decreases. The air on the top of the wing has further to travel in the same amount of time, therefor moving faster and lowering it’s pressure. This allows the high pressure under the wing to push it upwards.
2. Newton’s Law of Motion
Each action has an equal and opposite reaction. Air on the bottom of the wing is deflected down which pushes the wing up. Angle of attack important. This is why a flat plate foamie can fly.
Airflow and Stalls
The common denominator between these Bernoulli and Newton is… Airflow! Too little airflow means you will “stall!” You have to have air moving over your wing or you can’t generate lift.
Stalls are the biggest enemy of any new pilot. They result in loss of control. Most beginner planes recover from stalls more quickly than advanced planes such as jets or warbird.
There are two types of stalls to watch out for.
Low Speed Stall - This occurs when your aircraft drops below it’s “stall speed.”
Tip Stall - This occurs when you try to turn too tightly. The wing on the inside of the turn moves through the air slower than the outer wing. The inner wing loses lift and often pulls your aircraft into a death spiral.
How do I keep from stalling?!?!
"When in doubt level out." A 20-30 degree incline or bank is a lot! Try to keep your plane fairly level. It’s not like a car… you can’t turn sharp or stop.
More airspeed means more control. But be careful. Your reaction time needs to mature.
Fly your plane high and learn the stall speed. When you get used to what it feels like to stall, it'll help you land without stalling. HERE is a good episode to learn about landing.
Control Surfaces
There are are 3 major sets of control surfaces. The control surfaces deflect the flow of air, in turn, pushes the control surface the opposite direction. This changes the angle of the plane on that axis.
Elevator - Controls the pitch angle of the airplane. The elevator is situated horizontally on the tail of the airplane.
Rudder - Controls the yaw (Left and Right). The rudder is situated vertically on the tail of the airplane.
Ailerons - Controls the roll, or bank of the airplane. The ailerons are located on trailing edge of the wing.
Elevons - Controls the pitch AND roll of an airplane. The elevons are a combination of the elevator and ailerons situated on the trailing edge
Transmitter
Transmitters are normally classified as MODE 1 or MODE 2. Most people, including the entire Flite Test crew, use MODE 2 transmitters.
The “High Five” episode will help you remember the proper movement of your control surfaces.
Click HERE to learn how to choose the right R/C plane for you.
If you know someone that may benefit from this article, share it with them. Help us make this hobby friendly and approachable!
Choosing a Plane
I was just excited to see Flite Test teaching Bernoulli's! This is almost all of lift generated with an airfoil. Newton has so little effect that it is not even mentioned in training manuals.
Thanks again you guys are great!
REF: Aerodynamics for Engineers (5th ED)
By: Bertin & Cummings
as you say, "therefore, Bernoulli's principle still applies".
Very nicely done video, however there is one myth that has been perpetuated here.
The airflow moving over the top surface of an airfoil does not increase in velocity because of having to travel a further distance. It is the venturi effect present over the upper wing surface that trades static pressure for kinetic energy, i.e the Law of Conservation of energy. Distance has no effect on this.
I have seen this explanation for lift literally everywhere, but it is very misleading, and only leads to confusion when describing symmetrical, flat plate, or inverted airfoils.
Either way, Keep up the great work; You guys are bringing more people to this hobby than anything else in at least a decade.
G.
I also don't understand how on an asymmetrical airfoil, as the air hits the leading edge, splits and progresses along the airfoil how it knows it has to speed up over the top surface in order to meet up with the bit of air it split from by the time it reaches the trailing edge. Why doesn't the lower air simply wrap back around the trailing edge to 'catch up' with the upper air causing turbulence?
but... they are typically flown at some angle to the air
or control surfaces are deflected, making the wing non-symmetrical
and at high speed - think aerobatics - only small changes are sufficient
(v is squared in the lift equation)
I stumbled on your site by chance and since then I'm addicted. this is explained with pedagogy. keep it up.
greetings richard from holland mail rkleveringa@tele2.nl
Think also of a GEV ram-wing: It isn't flying via Newton's reaction, but by increased pressure under it. Same with an air-cushion, for that matter)
Also, relating to the round-wing very short aspect-ratio planes, when flying super-slowly at high _A_, it creates "parachute lift" or "vortex lift" to fly super-slow: The huge wing-tip vortices wrap around and keep the flow from the LE over the top from separating, so they do not stall. It traps a "bubble" of low pressure above it, allowing it to fly so slowly. Successful IRL examples: the '30s Arup planes, the '30s Nemeth "Parachute Plane", the '80s Hatfield "Little Bird" (follow-on to the Arup), and the '90s Wainfan "Facetmobile" all of the very short aspect ratio sort. They do not fly via bouncing air off the bottom and reaction via Newton, but by pressure differential.
To say that a normal plane flies via Newton's reaction and all these other situations operate via Bernoulli is too much of a complex explanation.
Always Bernoulli, very rarely if at all, Newton.
or ask 'how is lift is produced?'
NASA has a few clues - just search for 'nasa theory of lift'
