The Flite Test Beginner Series is brought to you by Horizon Hobby.
Episode 1: Choosing a Plane
[video='http://youtu.be/dOziFzntXq4']
Choosing A Plane
Choosing a plane can be a very difficult and intimidating decision. In this first episode of our beginner series we discuss some of the most common things to look for and help you choose wisely. Here are some important things to consider:
Keep it to 3 or 4 Channels
Choose a plane with 3 or 4 channels to start. It’s best to start simple and get used to flying. A 3 channel plane usually consists of thrust, rudder and elevator. The fourth channel often adds the aileron function.
Alternatively, a 3 channel flying wing, or delta design has the aileron and elevator functions combined into elevons. In order to roll or bank the elevons move opposite of each other. To control pitch they move together.
Aileron - A hinged flight control surface usually attached to the trailing edge of each wing of a fixed-wing aircraft. Ailerons are used in pairs to control the aircraft in roll, or movement around the aircraft's longitudinal axis, which normally results in a change in heading due to the tilting of the lift vector. Movement around this axis is called 'rolling' or 'banking'.
Elevator - Flight control surface, usually at the rear of an aircraft, which controls the aircraft's longitudinal attitude by changing the pitch balance, and so also the angle of attack and the lift of the wing. The elevators are usually hinged to a fixed or adjustable rear surface, making as a whole a tailplane or horizontal stabilizer.
Rudder - Used primarily to counter adverse yaw and is often not the primary control used to turn the airplane. A rudder operates by redirecting the airflow past the fuselage, thus imparting a turning or yawing motion to the aircraft. In basic form, a rudder is a flat plane or sheet of material attached with hinges to the aircraft's vertical stabilizer.
Choose a Slow Flyer
It takes a little while to gain the muscle memory and response time to fly a radio control plane. A slow flyer will give you more time to react to mistakes and improper inputs. Slow flyers don’t seem cool at first… However, you’ll be surprised at how quickly you fall in love with a good flyer before the one that looks cool.
Start With an Electric Plane
Electric planes used to be cumbersome and under-powered. Today’s electric R/C planes have plenty of power and are much easier to fly and maintain than fuel-based planes. Gassers and nitro planes are pretty awesome, but learn to fly, crash and repair before you add the complication of an internal combustion engine.
Foam is Good
Foam is your friend. The fact of the matter is, your first plane will be trashed. Foam is durable and easy to repair. Balsa planes are beautiful and there is nothing like them. They are works of art that look great on the shelf and in the air. Not to mention they stand the test of time. But don’t start with that beautiful balsa plane. Learn on an inexpensive foam plane that can take some abuse.
Dihedral and High Wings Help Keep You Level
Dihedral is the gentle v shape to the main wing. This helps keep your plane in the upright position. Generally you’ll lose some ability to do aerobatics, but you’ll gain more stable flight. The position of the wing is also important to stable flight. The lower the wing is on the fuselage the nimble the plane becomes. For your first plane, we suggest you go with a high-wing orientation.
Don’t Go Too Big… Or Too Small
It’s important to choose the right size plane for the space you have available. In general the smaller and lighter your plane is the more crashes it should be able to endure. This also means that it’ll be more sensitive to wind and will probably be more squirly. Bigger planes tend to be more stable, but they need more room to take-off and land.
Park flyers are a good size to start with. They are usually around a 36” wingspan and require a 600 X 600 foot open area to fly.
Go Ugly First
EDF Jets and Warbirds are very enticing. They will only disappoint you for your first plane. Jets and Warbirds are usually meant to fly fast and respond quickly. If you’re just starting out, you’re not ready for that yet. Don’t worry, it won’t take long. For your first plane stick to something ugly that flies well. That way you won’t be as crushed when it hits the ground!
Look For an Easy to Repair Plane
By this point in the article you’ll notice a trend… You’re going to crash. Just accept it. It’ll make it easier to stomach when it happens. it’s just part of the hobby. So, when you do crash or break something, can you back up and flying? Make sure you can buy replacement parts for your plane. The number one replacement part is the propeller. It’s good to choose a plane that has common and easy to find parts.
Learn on a Simulator
If you think this is a hobby you want to stick with, a simulator is a worthwhile investment. They are very accurate these days. We did two previous episodes featuring simulators here:
Flite Test: Learning to Fly on a Simulator (Phoenix)
Flite Test: Simulator Flying (RealFlight)
Different Types of Packages
RTF (Ready to Fly)
Most expensive
Most inclusive (has everything you need)
Quickest to get into the air
Little guesswork/Research
Predictable Performance
BNF / RXR / PNF (Bind-n-Fly / Receiver Ready / Plug and Fly)
Let’s you use your own radio system
Good second airplane
ARF (Almost Ready to Fly)
Often requires your own electronics
Widest selection of manufactured aircraft
Some building skills required
Requires more knowledge on electronics and setup
Wide performance “envelope” based on electronics and setup
Kit
Most time to get into the air
Requires strong building skills
Results may vary depending on your ability
Scratchbuilding
More work
The cheapest
Most fun
If you can build it you can fix it
Widest variety available
Best skill development
Flite Test Recommended Planes For Beginners:
Manufacturer | Model | Notes | Channels | Package | Price |
HobbyZone | High Wing Trainer. Easy to find replacement parts. Very durable. | 3 | RTF, BNF | $170 - $200 | |
HobbyZone | High Wing Trainer. Small and inexpensive. Easy to find replacement parts. Needs to fly in very calm weather. | 3 | RTF | $90 | |
Flite Test | High Wing Trainer. Only available as a speed build kit or scratch build. Easy to repair. | 3 | Scratch Build, Kit | Free - $33 | |
Flite Test | Flying Wing with a rear mounted propeller. Very durable! Only available as a speed build kit. Easy to repair. | 3 | Scratch Build, Kit | Free - $28 | |
Composite | Flying Wing with a rear mounted propeller. Comes as a kit requires some building. Most durable! | 3 | Kit | $60 | |
Parkzone | Powered Glider. Fly exceptionally well. Kind of large and requires a larger flying space. | 3 | PNP, RTF | $160 - $250 | |
Hobby King | Rear prop. Very durable. Easy to repair. Exceptional flyer. | 4 | RTF, ARF, Kit | $57 - $103 | |
FlyZone | High Wing. Easy to buy replacement parts. Good second plane. | 4 | TXR | $210 |
We would like to thank Horizon Hobby for sponsoring this Beginner Series! Let us know what you think of this content and let Horizon Hobby know as well! You can find out more about Horizon Hobby HERE.
HorizonHobby-BeginnerSeries
Basic Aerodynamics
i am new here
i would like to ask you , what tools do i need to start building ?
is there a tool box that made for building an rc planes ?
i tried to look in hobbyking but i didnt find
with Aloha
-Garret
The only thing I am yet to come across though is how to calculate power systems for scratch builds. Mostly I have gone off of the recommendations... but is there something I am missing? Searched the web also and couldnt really find anything. My son made a Nutball and we put the DT750 on it with a 3 cell and it just corkscrewed in the air... thinking too much power! But how do I work out which is best? Thought I'd mention it as maybe something to think about in the upcoming Beginner series.
Anyway, great job once again guys, blessings to you all!
Thanks
Happy Flying, Peter V.
I'm a fan of the work you do and the excellent site for a long time.
I live in Brazil and I maintain a blog with various information about electric model airplanes, such as tips and records practices of weekends with model airplanes.
I would love to have permission to publish this series called 'Beginner Series' for Brazilian practitioners follow closely in my blog.
I see that the reports are very comprehensive and useful, but many here still do not know Flite Test!
I have his permission to replicate www.aerovolts.com blog post?
Congratulations for the work and thank you for your attention.
Success!
Daniel
Thanks,
Thank you for all the great information. I am learning so much from your site. This article will help me choose my first plane. Can you do or point me to a good article covering the chose of a first transmitter?
I did feel like a total schmuck though the other day when my youngest was moving the radio sticks way too far and crashed the FT Flyer. I kinda barked at him about being gentle on the sticks and not crashing. Of course, he thought I was mad at him and started to cry. Not a great way to get the kid interested in RC Flight, huh? Just like you said in this video, be supportive and calm to those learning to fly. I felt bad getting on his case for crashing a $1.00 piece of foam. I told him, "Well, we both are still learning, huh?"
However, he was happy again when I told him I'd cut out a new FT Flyer and he could build it with me. Again, thanks for all you guys do to get everyone involved in this awesome hobby.
Chad, Josh and Josh great job but the video seemed rushed much like you had forgotten to do the video and quickly ran out to make it. You had a lot of good info but it felt forced down your throat. I realize its hard to give out info and hope to keep your audiences attention but a little more explanation would have been nice. For example you defined dihedral and said it will help you level out, but that was it. I as a new person did not learn about the importance of dihedral in choosing my plane. You can memorize 2+2=4 but if you don't know why 2+2=4 did you really learn it? What i did like about it was the visuals I am a visual learner and you had enough visual at times to help get the point across by not using "Death by Power Point" Overall I thought it was very good. Just my 2 cents worth. Looking forward to more from the series
Great Job keep it coming!!!!
It's a flying wing, it can fly slow, right?
I just didn't want to buy 2 or 3 planes just to get to fly what I really want, you know?...
Thanks for your opinion!
LOVE the Flite Test swappables. Fun, cheap, and easy to build.
BUT they are only 3 channel.
How about a fun, cheap (foam board), easy to build 4 channel from Flite Test as a 2nd plane?
Something stable (high wing?) and slow to help learn how to deal with ailerons.
(I know, it would require at least one more servo for the ailerons but assuming you had a 4 channel receiver in your power pod, it would mean just one more servo to connect.)
Maybe add ailerons to the FT Flyer?
Damig, (Aces High Flight Sim nickname)(now I get to build and fly)
aka Miggy... scott
Whomever is responsible from Horizon for sponsoring the guys from Flite Test should get a raise because by having the for sight to help with this series has earned my respect and my business! Thank You
First I want to thank both of you for an excellent series, which was extremely helpful. I have always wanted to get into RC planes and finally decided to take the plunge. Before watching your series, I started searching for the perfect RC plane. I did an extensive amount of research and was fortunate to purchase an excellent trainer, the Hobbyzone Super Cub DSM 7400. Then everything went down hill. The first time I took flight, it lasted about 30 sec. with a substantial damaging crash. I tried a second and third flight with more damage. At that point I decided to do some more research and find out the does and don’t s. That's when I found your beginner series. I watched the first five episodes, before attempting to do any flying. I watched the take-off and landing episode twice. I followed all of your instructions and did everything like you said and before I knew it, I was having awesome, consecutive successful flights, with each one getting better. All of your info and tips were spot on! You guys are awesome!!! I cannot thank both of you enough. You guys make a great team and do an excellent job describing what to do and what not to do. I also watched additional episodes, like damage repair and aerobatics. I'm now flying without crashing and also purchased my second plane, a Parkzone ultra micro P40. Using your video's and tips, I am flying that plane as well without crashing. I love the series so much, I sent links of the the series to my dad who has been struggling to start RC flying. One of the most important information I got from your series is about purchasing the right plane! It is so important to purchase a plane that is by a reputable company with available spare parts. My dad did not follow that advise and is regretting it every day. Again Thank You so much and keep up the excellent work.
Thank You
