Unbreakable $1 AnyCopter Motor Mount with Legs
by ultramicrobe | November 30, 2013 | (11) Posted in Projects
There are several inexpensive bell-type motors that are great options for the AnyCopter, but if you have had experiences like I have, you probably hate the motor mounts that come with them. The problem is the two grub screws that hold the motor on tend to work loose, and then off goes the motor. Not necessarily tragic with a plane, but with a multirotor the outcome is likely to be worse.
I made an AnyCopter a while ago and designed some motor mounts for the Hextroic 24g (but will work with any similar motor) that have been working really well, so here are instructions. They cost about $1 (for 4, so 25 cents), and have very workable, sturdy legs that are not so huge they interfere with airflow.
Parts list:
4X 1.5” of 1/2” square aluminum tube
4X 1” of 5/8” square aluminum tube (telescoping with 1/2 tube)
4X 8” of 3/32” piano wire (very hard to bend wire)
8X 20mm M3 bolts and locknuts (or similar)
To start, take the 1/2 square tube and drill a hole that is slightly undersize for the base of the motor (like 1/64 less than the measured size) about 1/2” from one end. Then cut a small slit from the same end through the hole, and a bit past it to give a “saturn” profile like in the picture. Drill a bolt hole perpendicular to this about 1/4” from the end.
Slide this piece about half way into the 5/8” square tube, drill bolt holes in both, and bolt them together (see pictures at end for final set up). Now slide the 1/2” wood rotor arm into the other side of the 5/8” square tube, making sure the fit is very tight. You can put a screw into this too if you want. I sanded all this down and rounded all the edges to make everything smooth (and not likely to cut wires etc.).
Now here is the important part. To mount the motor, pry open the ‘mouth’ of the hole very slightly to make the hole big enough for the motor base. Slip the motor into the hole and squeeze it shut a bit. Now put the perpendicular bolt in place, and when you tighten it, the jaws of the mouth will shut VERY tight, locking the motor into place. The surface area and force locking the motor into the mount is quite significant - I have tried to remove the motor by force, but can’t.
Now make 4 legs. Simply cut 8” of 3/32 piano wire, bend a 90 deg. tab of about 1/8 or so on one end. Then bend at 4” to about 45 deg., as shown (this bend does not need to be exact, just don’t bend too acute since the ‘spring’ keeps it in place).
Drill two 3/32” holes in the bottom of the mount about 1” apart, the second one should be far enough from the end to be into the wood. Put the tab end into the hole closest to the end (as shown).
Now squeeze the wire and push the other end into the second hole. It should be tight, work it right into the wood until its all the way. The spring of the steel keeps it in place unless you missed the wood or make your holes too big.
The copter should not sit level. These legs are not like rocks, but they are not supposed to be. On a hard landing they will flex or even bend sideways. Just bend them back, or make a new one if need be. Another interesting feature of these is they will stick in soft ground on hard landings, so no bouncing! Makes it look like you peg every landing.
Here is a close up of the final product, bolted on. Note that if you used a larger bell motor, you could do this with a single piece of 5/8" aluminum instead of the two telescoping parts, but the base of the 24g HexTronic is not long enough to be held tight by a 5/8" tube.
eagle4 on November 30, 2013
great idea mate. very clever :)
Flynn on December 5, 2013
You've done it again! Great article. I'm glad I've waited on building a quad.
Cyberdactyl on December 5, 2013
Clever idea.
I use the DT750s that have a similar motor mount. I found if you Loctite (blue) the grub screws, the problem of them working loose is eliminated.
ultramicrobe on December 7, 2013
I am sure that is true, I seem to have bad luck with loctite but probably because I am messy. I guess here the point is that you still have to make some kind of mount (so why not skip the problem altogether) and this has the bonus of an easy way to make legs - likely a bigger problem. For planes though, you are right, the mounts are adequate if you use them correctly.
Kyle Bower on December 6, 2013
Cool I have been trying to get into Multi Rotors. Any advice?
I am no expert, I just wanted to try it - so my advice is just to give it a shot. In retrospect, if you are just building a quad, I would buy a frame kit, since you can get one for $20 with glass fiber and aluminum and you can always replace bent arms with wood later if you want. Then I would put these motors and mounts on it, and get a KK board since they are easy to program for a beginner. If you hate it, you recycle the motors into some airplane building project. Mostly I just wanted to build something easy to fly so I can make movies with it.
kenc3dan on December 9, 2013
Elegant solution and it may save weight. I wonder how much the DT750 bases weigh?
ultramicrobe on December 21, 2013
Just an update - these legs have taken a pounding as I learned to fly a quad. I have smashed down hard lots of times, and a few times upside down. The other day my battery died at about 80' up and it just fell out of the sky sideways. Broke a wooden arm, but the mounts and legs are holding up great. I also pounded the motors into the mount so hard once that I had to loosen the nuts to push them back out, but was flying again in minutes. They seem pretty tough. Much better than the glass fiber ones out there on a lot of quads I think. I need to figure out a way to mount NTM motors on something like this.
