To the FliteTest Community,
The MESArcFF team was fortunate enough to receive two tough tilts from Josh and the FliteTest gang a couple weeks back and we were planning to create a tricopter and Dragonfly setup with the equipment when it was mentioned by a couple students that we should try a Dualcopter instead since we had never ventured in a multirotor like this before. It was a lot of fun trying to figure this copter out since our initial finding of info on the build was nowhere to be found. We did however come across this forum on Rcgroups that made the process super easy, we highly recommend that if you plan to create a dual copter to read and follow this forum. With the exception of personal setups and tech differences, he was spot on in terms of directions.
http://www.rcgroups.com/forums/showthread.php?t=2187965
So a HUGE thank you goes out to Robertoho for creating this forum, you rock man! In terms of parts we highly recommend the KK2 board, stand TX and RX, standard 450 size multirotors, the TOUGH TILT, and the servos FliteTest sells with them. It was very cheap to construct since it doesn't require too many parts, and the frame was a used Heli we got from a donated mall copter.
Here is Jake working on the original setup before switching over to the new equipment.
The Dualcopter performance is pretty much just a hover, however, they look so cool!
Tough Tilts were the way to go for this project, very easy for the students to work with.
A big thanks goes out the Robertoho for creating the forum and FliteTest for suppling the group with those Tough Tilts.
For more information about the program; http://www.mesarcfoamfighters.com/
Thank you,
The MESArcFF Team
I was just thinking....
Would this technologi make it possible to build a twin rotor chopper in Chinook style, without the very advanced dual swash plate, pitch mechanism......?
Or someone in the community...
I like the look of that thing ! very cool looking . Makes me want to build one , lol .
Simply as a selfish suggestion , I would like to see you all go ahead and turn it into a tri coptor now. I think it would be awesome to see it fly thru the air in a controlled manner and you would still have a very unique looking build.
Makes me want to look for an old coptor at a flea market and build a tri coptor now.
Thanks again .
Anyway, great build everyone, keep up the good work!!
I was thinking about this last night, why is there a pendulum effect with a dualcopter but not with chinooks? Do they just have more advanced avionics, or does it have to do with the control setup.
Also everybody builds these like the avatar gunship. I'd like to see one built more like a chinook. Where the tilts control side to side stability and forward or backward motion is controlled by rotor speed. Should be fairly simple. It'll look odd, but I bet it would fly well.
Maybe one day my wife will let me drop the cash necessary to get into this stuff. ( I'm literally starting at zero, no tx no chargers no anything except a tiny hubsan x4) any suggestions on how to convince her would be appreciated.
Challenge: Monocopter!
