This is the 2nd part of my build and review. Initially I wanted to only do a short unboxing on one evening but than, by playing around with this system I had so much fun that I completly assembled it, did a quick setup and found it so easy.
Even the video downlink, gimbal and retracts worked on the first attempt.
As noted in the video: I'm still waiting to get the copter back from repairs and see if I like the flight characteristics. Maybe it just needs some getting used to.
Also wanna see how much more efficient the good props are compared to the standard ones. If the Aeronaut Camcarbon make a difference I will show it.
Is something to detailed and boring here? Or should I go into more detail in some regions - please tell me and the next review will be better!
Here are the specs:
Size: 450mm (motor2motor)
Weight: 2.25kg
Motors: 28x14mm 450kv
ESC: 30A - 6S
Props: 11x5
Flighttime (in hover with gimbal and cam):
~15mins (used 1462mah for 4:39 flight and calculated the estimate flighttime for save 80% battery usage)
Pricetag:
1100€ (RTF with Copter+Charger+Gimbal+Radio+Battery)
+ 250€ for FPV Set (TFT+RX and TX)
Battery-Bay (Plastic housing):
3,5cm height
8,4cm width
housing is around 16cm deep (but you need to get cables in there...)
orig. battery without housing:
13,5cm x 7,2cm x 3,2cm 6S 6000mah 8c dicharge (48amps) 1c charge
Morpheus Gimbal: for GP3 and GP3+ (not GP4?)
Weight: 280g, 2s-4s voltage
Tilt: 90° Roll: 45° Pan: 360°
Flight controller Gains:
without gimbal: (set per default)
Roll: 55
Pitch: 55
Sway: 95 (Yaw)
WITH gimbal (a bit heavier)
Roll: 45
Pitch: 45
Sway : 80 (Yaw)
FPV Set:
7" TFT monitor with sunshade and good brightness!
Internal battery, chargeable via USB plug.
8ch: 5733 5752 5771 5790 5809 5828 5847 5866
Infos: http://ttrobotix.com/product/ghost-plus-with-h3d-360/features-4030-f12
German instructions and tons of infos: http://www.drohnen-forum.de/index.php/Thread/6838-TTRobotix-GHOST-PLUS-Anleitungen-Handbuch-FAQ/
German FPV SET description: http://www.drohnen-forum.de/index.php/Thread/7480-FPV-Set-inkl-FPV-Monitor-f%C3%BCr-TTRobotix-GHOST-Thunder-Tiger-Anleitung/
No Comments Yet
Be the first to leave one!
