the build and flight of the STINZER
by brianm311 | July 7, 2013 | (4) Posted in Projects
this is my stinzer my first attempt at my own design useing a few ideas from some other planes the body measures 40inches lng by 5inches wide by 51/2 tall down to 21/2 at the tail it is similar to the stinson reliant
the nose cone came from a glassair sportsman i did some repairs to for a friendnotice how close the pod is to the aileron!! after prop clearance adjustments this was the final resting place!! phew thats tight!!
this is the finished wing didnt run the wires inside since it was going to be a top mount wing i used the lazertoyz motor and esc combo they sell for the cruzer.                  (stinson/cruzer=STINZER!!!)
removed some of the length from the engine pods to make them fit the wing wanted to change the look of the wing just a little for a different look
top view of the stock cruzer wing
checking prop clearance to see if i could use a cruzer wing
checking rudder and elevator to make sure there 45degrees
i origanlly went with a tail dragger but decided to make it tricycle instead
note the shorter pods hope they work like that!!
all stickered up and ready for a maiden!!!
brianm311 on July 12, 2013
that's a good idea! didn't think of that during the build thanx
RotateB4TheEnd on July 12, 2013
Interesting little plane! It'd be cool to add in the split flaps feature!
Captain Crash on January 27, 2014
ok not that big
brianm311 on January 28, 2014
and it fies sweet! I recently swapped out for a single motor and the plane is a fun time to fly
you know its like the duet's identical twin except it huge
