P51-B Mustang build
by scottie | June 14, 2014 | (17) Posted in Projects
Theres no introduction needed for this plane,the P51 is iconic,here is my scratch built version.
BTW this is a big article :P
The painted one is mine,the other I built for my mate,paint scheme to be finalised but I think he is edging towards this paint scheme so should be quite cool :) .....
Anyway,I've already done an article prior to this one covering the story this far so onto the build as promised.
I build using a heavier and denser board from DTFB,I'm guessing from what I've read on the forums that its similar to Elmars FB.It's from Hobbycraft,5mm thick and is virtually impossible too remove the paper without destroying the board.It's far more robust and durable but it is considerably heavier.
The build pictures are from the painted version shown above,the white one,has already gone through some changes in the build method and it shows,it flies better than mine ....typical :(.
This was never going to be a swappable plane,I designed this to be more scale looking and too hold much larger motors including if wished ,doubling up the batteries.We've tested the white one with 2 x 2200mah 3s...it was interesting :).I've flown mine with 2 x 1800mah 3s much to my delight they both fly beautifully.
Being built as they are,cooling was a concern so where ever I could,I allowed for venting,the White one with the spinner off gives an incredible noise from a steep dive :) big smiles that day .
Fuselage
formers and battery box
fuselage sides and motor
assembled....
motor installation
battery hatch
doubler for wing seat
joining the 2...
tail
verticle stab and ruder,doubled of course ;)
elevator
fitted
servos,esc and wing mount
if you read the last article you will know I had a failure with the control snakes I used which resulted in a crash,I went back to a tried and tested method,a pushrod,only I used 3mm carbon rod with adjustable clevices.
rear turtle deck....lots of 50% cuts required too allow a smooth curve
front cowling again with the 50% cuts and some careful shaping
trusty pink insulation foam....I love that stuff :)
air scoop reinforcement
yep....pink foam :)
a couple shots of the white one with some modifications,mainly in the motor mount area too allow for additional cooling
I also added wooden reinforcement too the fuselage sides
sisters....
Wings
 main rib
removable servo mounts
 flap and aileron servo access
ready for paint
some in flight pictures.....and my buddy :)
and a couple of videos
http://youtu.be/RwTJoUp1szk
http://youtu.be/URjMfs0OpQo
So there you have it folks,my P51-B,about a year in the making but it was worth it,I'm quite rightly happy with her,they both fly beautifully altho mine has a slower roll rate than my mates but I can live with that,I'm just trying too enjoy flying her altho,a typical scratch builder that I am,I'm already planning my next build ;-) and further refinements too this bird.
Thats it from me for now folks,please rate and feel free too comment or ask any questions.
Cheers
Scottie
JamesWhomsley on July 1, 2014
Wow, awesome article man. Your construction techniques are quite remarkable. The two planes look fantastic. I would love one my self. Makes me wish I'd started my vampire with these methods of building. :) Nice one.
scottie on July 1, 2014
Thanks James,appreciate that.Yeah the power pod does influence how your builds turn out but then We've already had that conversation :)
danielmiceli on July 8, 2014
Hi Scottie, this project is awesome, would love to be able to make it. I live in Brazil, and believe it is difficult to buy the material design by internet. This project is available to buy? I would be very happy to make it by myself. In case that`s not possible, ok, no problem!
Congratulation...great work!!
Thanks everyone for your comments.This is a working progress and I do want to release the plans but I'm starting on my third build of this model and every one has been slightly different,so as soon as I have finalised the plans and build process I will share the plans.
Thanks again for your interest.
LordVader on July 1, 2014
Very nice plane, everyone always does the D version. Glad to see a B version out there. Would love to see your final version and some plans. Thanks for sharing.
scottie on July 2, 2014
thanks Darth :)
Yep,the P51-D does seem to be the favourite but I do kinda like the B myself.I am still working on this,actually hoping to put another one together by this weekend for further modding and testing,guess it will just have to be a 'watch this space' for the final version .
cheers
LordVader on July 2, 2014
I like the B version just as much as the D. I will definitely be watching for this one. Your planes look so scale and so refined, like the ones that are produced and sold. When I build one, I hope I can finish it half as well as you have. 5 stars and watching:)
scottie on July 4, 2014
Again .... LordVader,Thanks man, It means a lot when others can appreciate something you've built like that.
cheers
LordVader on August 6, 2014
Hi Scottie, just wondering how you are coming along with the refinements. Can't wait to get my hands on a set of plans. Every time I come back to this article, I get that much more excited. Patiently waiting.:)
scottie on August 7, 2014
Hi lordVader,I'm still working on this model I'm afraid.
I've been busy with work commitments lately and am just struggling too find time to finish this! that plus I've kinda started on a new project ;-)
I have however built another fuselage ,just need too build the wing,this plane just keeps
growing....its not that much bigger physically but it already dwarfs the FT Spitfire !
If this version fixes the GoG issues then I will hopefully be able to finalise plans and release them.
Thanks for your continued interest tho,
Scottie
LordVader on August 7, 2014
No hurry Scottie, don't want to rush you any. I was just curious how you are coming along with the final/next version. I really like the B version and your rendition is awesome. I am curious about your next build too.:)
scottie on August 8, 2014
The trouble I'm having is putting the plans onto sketchup,this part is a learning curve for me.Normally I make models as I go along,so every one is always slightly different from the last.
The new project is a simpler build but made to the same design as the Mustang so I'm hoping to learn 'how' to finalise plans using this model 1st then it's the back to the Mustang ! :) as for your curiosity,it's a model I hope can be used as a trainer :) thats all I'm giving away for now :-P
cheers
scottie on June 30, 2014
Thanks !
Dice on January 31, 2015
Hey Scottie, I love your p51b looking awesome, wud like to build 1 my self or even buy a building set from u....
scottie on January 31, 2015
Thanks Dice,plans will be available eventually !
I'm working on a couple of other builds atm but the P51-B is on the to do list.
cheers
Dice on February 1, 2015
Ok bro, good luck with your builts
BuckE67 on June 30, 2014
Great looking P-51!
joyster on July 5, 2014
Beautiful model Scotty. I am very impressed by your design and build skills - and your taste in subject!
scottie on July 6, 2014
Thanks joyster :)
rcflyer729 on July 1, 2014
looks really nice
Yogenh on July 2, 2014
I think that you did great. I really like the looks of the B. I would love to have one just hope that I could do it half as go!! Will be watching
Thanks,
The B is my favourite too.Once I get the design and build techniques finalised I will be sharing the plans...so.... you can have one :)
cheers
Yogenh on July 4, 2014
That will be great and I can't wait. Thanks
jrvalentin62 on June 30, 2014
Awesome job!!! Will you be considering sharing the plans. I'd like to try it.
Okie on June 30, 2014
wonderful looking mustaing great job plz share the plans
AceDoorman on July 5, 2014
GR8 JOB !!! Love it. How long did it take to build?
Thanks,
The white one,from drawing plans on foamboard to what you see took roughly 30 / 40 hours.
KGFlierAIA on July 1, 2014
Wow--really nice build. It was a shame to close up the intricate interior work--beautiful craftsmanship. Thanks!
Yeah I know,I thought that too,thanks
cardinals1225 on July 3, 2014
Awesome job! That is the sweetest foam board plane I have ever seen.
txwn on July 4, 2014
very good!
Thanks
cardinals1225 Thanks ...that is quite a compliment :)
nuff said :)
cheers
furryjock on July 4, 2014
Awesome!!! Great work
Thanks mate :)
Michael9865 on July 8, 2014
Nice, thanks for sharing. Anxiously watching and waiting for more updates.
Flying Fox on September 9, 2014
Beautiful Plane Keep up the good work.
scottie on September 9, 2014
Thanks dude :)
there's another one on the way.... ;-)
P51-B Mustang build
