the hobby champ rtf is a great beginner plane probably one of the best beginner planes. At first it may seem like a slow crusing plane but it's not - it is loaded with power. I would not recomend taking off from ground at first. instead hand lanch it, you get more thrust . also trim the throtle to a medium and do the rudder .When hand lanching use the cg point [holding at CENTER OF GRAVITY]
though every time you take out the li po batery you have to re -bind the conroler (like every small plane) .the first time you fly the champ
do not use full throttle it may lead you to a distance out of range .Also the controler is a this controler will bind to all models that have 4ch control. speaking of channels the champ is three but the tx is 4ch so ift any you ge any bnf thats 4 ch like a um t 28 you have a nice tx to help you. but if you have a spketrum dx 4,5,6 or any other spektrum tx you can bind it to those and get used to a common rc tx .
a fun fact the champ is based off of a real plane called the aeronica champion thats why you see the little aeronic logo so you may consider this a scale craft but the champion and the champ dont look exactly the same but its pretty close even the font is perfect
i think horizon got it right now they just need one with as3x system in it but our good freinds josh and josh have a video on it so here you go
happy flying!!!!!!!!!!!!!!!!:)
because if you do you can upgrade it .
And yes this plane does not handle any wind well.
add a stronger tail supporter and make slight aerodynamic changes you can make it a stronger plane . also change the level of skill .keep in touch so i can provide you with more
