Today we take a look at the Ready Made RC 5.8GHz FPV Quick Start Package.
Included you will find:
- RMRC-420N NTSC CCD Camera with built-in microphone
- ImmersionRC 5.8GHz 600mW Transmitter
- ImmersionRC 5.8GHz Uno Receiver
- RMRC 8" Monitor
- 1100mAh 3s Lipo for receiver and monitor with Y-Adapter and 2 Barrel Connector adapters
If you are also looking for a great beginner FPV platform, we recommend the FT Versa Wing. It is extremely durable and is built with only two sheets of foam!
David constructed a simple swappable FPV "pod" out of our FT Element Simple Firewall.
When starting out, it is usually a good idea to go with a monitor instead of goggles. If need be, it is much easier to look up from a monitor then remove goggles to find your plane.
To tower dive, or not to tower dive? That is the question. We say TO TOWER DIVE!
But tower diving comes with consequences. Here is just a bit of the damage.
RIP Mobius Action Cam 2013-2013. You were more than just a camera. You were a loyal and humble friend. We will never forget you.
So if you're new to FPV or just need a great setup check out Ready Made RC, and when you do, make sure to use the discount code FLITETEST10 for $10 off your order!
Thank you so much for watching! We truly couldn't get away with any of this stuff with out you.
Let us know what you think. Chat is up in the forums!
The resolution for 2014 could be for FT: Find the moebius cam....
Guten Rutsch ins neue Jahr 2014!
From Germany
You are always doing great FPV shows, but you have rarely addressed the issue of licensing. The readymade RC page for this rig has the disclaimer that in the US, you need to have an Amateur Radio license to use the system. Can you do an episode on how one would go about getting the required licenses in the US?
Thanks,
Josh Murphy
The video tx does not seem to be all that hot. The problem starts as soon as I start up the unit, I am connected into my flight battery on my quad at the moment 2200 mah 20c 3 cell ( turnigy ) I've tried with just another 1000 mah 20c 3 cell and still same issue. I have a video on the issue from my iPad I posted on YouTube I'll post the link below the picture will be great then a black out but when this happens the power stays on on everything. I changed over to the fox tech blue beams I think there called and it helps a little I just did a bench test if you will. Plugged everything up inside of my brick home walked outside a out 100 yards away and video only broke up a little in my googles then pool black and back... Seems like the signal jut drops all at one time idk. Sorry for the long reply but thanks for your help. :)
http://youtu.be/X5W3v0Hc3C8
