We wish we could take credit for this one, but this project was born and raised by the Flite Test community. Thank you guys so much!
With the Blunt Nose Versa mod you have plenty of space for your electronics, or more importantly, your FPV setup!
We went out to Furey Field with two of these guys and had an amazing FPV experience. Screenshots below!
This mod is extremely simple so we threw in a quick build after all the flying. If you want to build one yourself, you can pick up a Blunt Nose Conversion Kit in the store, or download the plans for FREE below.
We can't thank the community enough for the continued inspiration and support. This project wouldn't exist without you guys, and neither would the show! You are all amazing!
FEATURED USERS
LINKS
FREE PLANS
Have a mod for your favorite scratch build? Let us know! Chat it up in the forums!
Thanks,
Josh
Also I do like the let's fly format, do it again. Just split the build vid out. Awesome work guys.
I might try to put the PDF tiles into CAD and reverse-engineer a non-tiled plan....
Keep up the great work!
http://www.youtube.com/watch?v=3vyMZvyLe-E
https://dl.dropboxusercontent.com/u/8762676/Versa%20blunt%20nose%20untiled.pdf
Consider it a challenge. I would personally love to see something like that.
Thanks in advance
could you apply this too the kraken?
if so it would be amazing!
Cut & taped the plans Friday night, built late into the evening, setup the gear on Saturday and flew on Sunday. http://youtu.be/dM8VadNXtGI
I have one suggestion. I noticed the wing is showing the effect of my hand tosses. Were I grab on to. Now I'm wearing gloves since it is -17 but when I build my next wing I might add some extra foam spars in the "grip" area to help with this.
As always you guys are amazing.
I was very reluctant to make a wing due to the rear prop setup but after seeing this video I was so impressed. I can't wait to go FPV flying this weekend.
Cheers.
However, I prefer the old video layout.. Build separate from the other stuff. Also the word "Build" put in the title like the other videos.
Flite test is the best thing to happen to RC flight!! Keep up the good work!
I had suggested before you just have a tab for the pdf plans and then when you select the the plane there would be a linkto the review as well as the build video and a direct link to the forum. one stop and you have access to al the info youll ever need for all the ft planes.
thanks for all your work I love you planes and builds and all the info you provide. just amazing
thanks flitetest.
Thanks
Cheers
Mark
I'll have to get back to you when I figure out what that one thing is :p
Another awesome show y'all! Thanks for sharing the fun.
Frank
I send you this message from france.
My blunt nose versa wing is quite ready to fly.
I downloaded the plans. Great stuff !
The time has come to put a motor on it, but the instructions on the plan are not very clear. How many power? I plan to 150W. Is it OK?
How do i set the ailerons reflex on neutral position? slightly up?
Great thanks for your job.
Nicolas
Everything I wanted.
>Easy and fast build.
>20 min fpv flight with a 3300 mah.
>Something that would fit in my car rtf.
>Fast and Stable.
Thanks for the great plans!!!!
ps
I like the new format! I guess people don't know about that "seek thing" at the bottom of the video!!
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=29470&aff=83330
Im building one and got an 3530 1340KV aerodrive from hobbyking and gonna use a 9x5
for fpv. would love to know your setup
I also made a discovery there is a store called Omer de serre in Montreal, Qc, Canada and they stock black foam board 32"x40"x 3/16" super nice stuff $8 a sheet it stiff easy to work with, does dent or crease as easy the best stuff we can get up here in Cunuck land, since we can't get depron.
You can see the wing progress here --> https://plus.google.com/photos/106651899791066404508/albums/6000991391201011713?authkey=CKj8h-T8m-XVJA
Thanks again
