FTScratchBuild-Advanced
FT 3D Build Plans Available Here::
FT 3D - Swappable [ FULL SIZE ]
FT 3D - Swappable [ TILED ]
Click HERE to see the POWER POD BUILD VIDEO
3D Hobby Shop motor:
Omega 72g Brushless Outrunner
Equipment used in this build:
NTM Prop Drive Series 28-26A 1200kv / 250w
Hextronic 9 Gram Servo
TURNIGY Plush 25amp Speed Controller
FT Firewall
FT Control horns
1 mm piano wire (push rods)
Additional/Alternate components:
Suppo 2208/14 1450kv Brushless Motor (Park 370 equiv.)
APC-style Electric Propeller - 8x4E
BLHeli Series 20amp Speed Controller
Suppo SP-90 9g Micro Servo
More details on electronics for your Speed Build Swappable Power Pod
The FT 3D foam board scratch build is another addition to the swappable fuselage series.
Be sure to check out some of the other scratch build tutorials before taking on this advanced scratch build.
A full list of the electronics and components is available here.
If you'd like to purchase the firewall and control horns used in this scratch build, check out our web store!
In the tail of the fuselage, it's a good idea to leave the slots in tact until your are ready to install your rudder.
This foam swappable features a tapered symmetrical wing design.
The two wings are connected with a balsa wood spar setup which has proven to be very strong, holding up after multiple crashes in our tests.
The removable canopy hatch is another advanced design that gives you access to your fuselage as well as creating a streamlined looking aircraft.
The CG of this airplane is directly above the front servo slot. The plans have everything detailed for you.
Check out more images and join the discussion in the forum post! CLICK HERE
And as we mentioned before the FT 3D is also available as a laser cut Speed Build Kit in our store.
CLICK HERE to learn more.
It seems like the Speed Build & Swappable electronics and component list does not fit the FT 3D.
The wings plan is missing as well.
sorry for my bad english
Your the best Bixler thanks for doing all the build videos!!!!!
Keep up the great work!!!!!!!!!!!!!! ;)
what is the wingspan and the all up weight??
Thanks!!
Ford
With separate channels you have to play around mixing and takes up two slots, but if your radio can do it, i recommend this as you can set up flapperons on that setup as well, which might come handy on landing if you are new to this hobby, although I dont know how will this plane behave with flapperons.
My guess as for why this has 2 servos is that the ailerons are huge, and it would likely burn out a single 9 gram servo
Now I just need to finish the baby blender, crash it, re-stock material, and start this new buil. 😜
Great plans! Just moved to the top of my build list! Also can barely wait for the FT Cruzr :)
I am from Denmark. Great show you have. Thanks for all. Learned a lot.
I think you call it something like 'Dollar store' where you buy the material's
With paper on top. ?
I can not find anything like it in Europe.
Can you help. ?
With the Swede onboard my flying buddy''s have nick named you guy's ....
' The Flying Muppets ' :))
Kind regards Carsten Wu Sonderskov, Denmark
Say adjö to the swede. ;)
http://www.epp-versand.de/a_depron.php
In Finland we have depron which is available at different hardware and building supply stores. It usually comes in 6mm sheets (without paper) which means you have to adjust the plans sometimes to get the parts to fit neatly. I've built many of the FT series planes from it and it works great. Just be sure to use a low temperature glue gun so the depron doesn't melt.
Hälsningar från Finland :)
A couple of tips for anyone who is going to attempt the build:
1.) Tolerances are TIGHT!!! When Josh says the power pod to the fuselage is a "perfect friction fit", I don't think that accounts for the tape on the outside of the power pod. It is most certainly tight. The same applies to the wing spar location which is butted right up against the power pod, and the tail mounting. It barely needs glue!
2.) Get a good glue gun. Josh mentions it in the video several times, I thought he was kidding as my little mini-glue gun has successfully built the baby blender...this one is different. Get a 40W full size glue gun minimum. $15 from harbor freight tools.
3.) take your time cutting out parts. Remember how tight I said the tolerances are? A slightly misplaced cut can really kill this build. This would certainly be a good candidate for a "build kit".
Excellent build, can't wait to fly it!
Just an FYI, on the fuse plans the one of the folds on the canopy is labeled an "A" fold, but in the video you say it's a "B" fold.
Does any of these motors work with this plane?
- Turnigy Park300 Brushless Outrunner 1080kv
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19033
- NTM Prop Drive Series 28-30A 750kv / 140w
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=16229
Thanks.
http://www.hobbyking.com/hobbyking/store/__18968__Turnigy_D2836_9_950KV_Brushless_Outrunner_Motor.html
or if you want much more power I'd use this one http://www.hobbyking.com/hobbyking/store/__18969__Turnigy_D2836_8_1100KV_Brushless_Outrunner_Motor.html
I built this TF 3D but it was way too heavy... with small motor (28) and 1350ma lipo its weight was 700grs.
When i tried to use a 35 motor and a 2200mah lipo the weight was more than 900grs.
My plane did not fly, it was donated to my daughter and now is transporting Barbies and Kens around the living room...
The foam board i used has 5mm and paper on both sides.
What is the aprox. weight of this model without electronics?
BTW, I have no idea how Josh is able to make those super clean bevel cuts. The foam balls up on my blade and I end up chunking it out and then sanding it somewhat smooth.
When will this be available in a kit???
Cheers!
What size prop would i need for this application? if t can be done?
- Turnigy 3530/14 1100Kv
- Turnigy prk450 1200Kv
- NTM Prop drive 28-26A
I had to build in a little more structure so I could mount the battery back under the wing spar and it required a couple of coins glued to the tail to make it all balance. With this setup, it hovers easily and punches out like a rocket.
Thanks!
can i built this Plane with 3mm Depron? Or is a 5 mm Foam better?
Has anyone tried to built it with 3mm Foam?
Thank you
If you havent tried this plane, print the PDF plans at 110%, stick in a 480 motor, 30amp ESC, 9*6 prop and 2200 3cel battery, and I guarantee you will have a blast with it. Ive also designed my own landing gear option because I am not a fan of the Flitetest method (they buckle on harder landing too easy (the place that I fly has a rocky landing strip which beats up the plane on some landings).
Flitetest was a big part of us getting into the hobby a few years ago. Am impressed with how far you have come. I love the podcast and the swappable series....Brilliant!!!!
Just wanted to chime in here and say thanks to the FliteTest guys !! This evening I started into the build and have completed the power pack and one wing. TOTALLY AWESOME seeing it come together. I'm experimenting right off the start with an extra 3 inches of wing per side and will report how it goes. Cheers to all !
I only have one question. I may not be doing something right, or don't have the right throws, but I am not able to do a spin yet with full rudder and full aft stick. Am I not doing it right?
Anyway, I had never flown a 3D plane before and now I am pretty confident with it. Thank you Flitetest!
SKuhn68
SKuhn68
You should see my office, I have a hundred sheets of foam board and little pieces of foam litter the floor like an inch of snow.
Anyone else tried shrinking/expanding one of these planes?
Mike
