A4 Skyhawk EDF ScratchBuild
by AeroErgo | March 15, 2016 | (18) Posted in Projects
I allways wanted to have a A4 Skyhawk jet, but here in my country sometimes become too much expensive. Solution: Make your own EDF JET!
The challenge was have a good performance with just a 3S battery 25c rate of 1300mAh on a 55mm EDF that i can put my hands on, so the weight a become very important issue, so the construction was around the engine and the main part is the wing, all in one piece and the plane build it on it:
No CF rods on it, let´s keep it frugal :P
Later i put the EDF with a plastic film around it, 10% smaller on the rear:
Tail surfaces are just glued to the plastic film, not very stronger now but it will be with the side foams:
Here you can see the location of the ESC, just in front of the engine intake so get cool air frm the conduit:
Later i make a simple cockpit a nose cone and the intake sides on depron 3mm (on the final version i use 5 mm depron with better results)
Here you can see what the intakes are made of: Raid/Deodorant caps.
Now is ready to the maiden!! :
By the way, someone else experienced the "Dutch Roll" turbulence?  I saw it on this plane mostly when i have crosswind. I hope the guys of FliteTest make more videos about aerodynamics issues.
But thumbs ups after all:
A4 Skyhawk
High speed landings!!!!! ouchh
a4 skyhawk landing
Second flight: Now with some flaperon set to make it slower at landings
And some nice snapshot to make you forget the fact this is a model:
Specs:
Lengh: 730mm
Wingspan: 610mm
Weight: 490grs (On flight conditions)
Engine: 55mm EDF 4200kv aluminium case from HK (4S Version)
ESC: 30A HK ESC.
Battery: 3S 1300mah 25C Dualsky ECO
Flight time: 3:30 aprox.
After the first day of tests i decide make a new nose, more "scale" and a little transparent canopy with cockpit, some panels and seat.
A4 Skyhawk
I also make the vertical tail wider with a piece of light cartoon board to help with the "dutch roll"
A4 Skyhawk
Some paint job:
A4 Skyhawk
I don´t use plans, as ussually, (i know my mistake) ´cause i use to just draw the plane on the paper i will use as layout. Just i try to keep the plane proportional to the real one. Actually the  fuel tanks make it slower and shaky, but looks great with them.
One of my own demands was be a hand launched plane, nothing of catapults!
A4 Skyhawk
Here you can appreciate the increased wing area to reduce the wing load and the cheat holes to increase the airflow to the EDF unit.
And the last video with the final configuration:
The dutch roll still going on, mostly after i put the fuel tanks, but they looks so cool that i decide leave them on, after all they are very usefull to landing safe.
a4 flight
The high speed low level pass is his speciality:
a4 flight
I can say is totally posible make a EDF with small engine and small battery and get good results. A MUST on this plane was the "cheat holes" to increase the airflow, many of my field mates thought the plane just cannot flies on 3S, but it works! Keep it light as possible is allways a good tip.
Maybe next time i will add a rudder.... i miss the control on that situations when i flight close to the ground at high speed and i get a crosswind on the path and if i had a hard runaway, a landing gear, but maybe the weight will be too much for it.
Thanks a lot for read all this and sorry for my bad english.
Yogenh on March 18, 2016
You did a great job on it. Makes me want to have one just wish that there was plans for it. Will have to go over this again and see if I can work this out. It flies so good. Would love to see more so keep up the good work.
AeroErgo on March 19, 2016
Thanks!, i don´t use plans, but if you have some skills to draw it following the real plane sizes (proportional) is not hard to get good results, anywway, usually you have to make some modifications to reach better flight performance, as bigger rudder/tail, increase wingspan etc. I hope you start your plane soon and upload the results!
Yogenh on March 19, 2016
I have been thinking of using the 70mm EDF that I have so that I don't have to buy one. I am not very good at drawing but may have to give it a try. I just don't know where to start.
I start from the wing and then i continue building it up.
One thing I would like to know is how did you do the wing? I am not sure but did you use 2 sheets of foam boards to make it, Like one on the bottom and one on top?? It looks like nice wing and would like to know how to kame it
The wing is a entire piece on the downside, i add two pieces of balsa on the front of it. And a spar of pine wood. then i make 4 ribs on foam and i cover the upper part with 3 mm depron to make the camber. I keep it fat on the root and slim on the tips. The flaperons are made of two pieces of foam, like a sandwich with the hinges between them.
Drezed on March 21, 2016
Looks, and flies awesome! Love the detail work!
Jeff
AeroErgo on March 21, 2016
Thanks! flies really nice, but the Dutch Roll... The detail is based on the Argentinian A4 c Skyhawk C-305 of Malvinas War.
CrashRecovery on March 23, 2016
Bueno!!!!!!!!!!!!!!!!! Great Job on this!!!! Wish you had plans but oh well. Do you have better pictures of how you made the wings? I think that will help people better understand how you formed them.
AeroErgo on March 23, 2016
Sadly i didn´t take more pictures before i close the upper side of the wing. If you read a previous reply i explain as good as i can how i made it. The secret is make a bigger rib close to the fuselage, and a tiny where the main spar ends, so this way the wing is narrow on the tips and fat on the root. The bottom in flat to keep a high lift wing shape.
I hope you understand something hehe. In any case send me a PM if you need more details.
Epitaph on March 24, 2016
Really beautiful build!! Congratulations on the results!!
AeroErgo on March 24, 2016
Thanks a lot! :)
ncsky on April 7, 2016
Awesome job!
AeroErgo on April 7, 2016
Thanks. Now i`am working on a Saab 39 Gripen , i hope to make an article soon.
Agus_mdq on May 16, 2016
Excellent built my friend!!
Uaso, impresionante ;)
Estoy tratando de construir un F22 EDF para mi ahijado, con 2 EDF... 1 mt de alas... que me aconsejas en cuanto a los motores?
Abrazo
AeroErgo on May 16, 2016
Yo use en este modelo 55mm EDF aluminium case de HobbyKing, son bastante baratos y con 3S funcionan muy bien, sin sobrecalentarse. Además con ESCs de sólo 30A no se hace muy pesado el conjunto. Tambien se pueden usar algunos 64mm EDF que no consuman tanto amperaje.
Agus_mdq on May 29, 2016
Muchas gracias!!
La idea esta evolucionando... por ahora esta en un F-15 al ser considerado mas facil de volar para principiantes... veremos cuanto mas muda a medida que siga leyendo y aprendiendo mas detalles... abrazo
AeroErgo on May 30, 2016
Si, los aviones con doble deriva suelen ser muy estables y fáciles de volar, claro que suelen tener más resistencia al avance. Espero que pronto subas algún artículo sobre el modelo!, éxitos.
