Transferable / Adjustable Firewall Mounting
by TEAJR66 | March 17, 2016 | (12) Posted in How To
Here is a quick and easy way to produce an adjustable and transferable motor mount. To make this mount, you will need -
  • One firewall
  • ~8" of extreme packing tape
  • A piece of sandpaper
  • One plastic gift card
  • Scissors and/or knife for cutting gift card and trimming tape
This is a technique I have been using for mounting motors to my scratch built foam planes. This method allows for adjustment of thrust angles and movement of motors between airframes. I've mounted motors on planes with 48" and 60" wing spans using DT750 motors on 4S with 11x4.7 props. It has proven to be strong and reliable as well as durable and resilient.
Most of the planes I build use 2" outer diameter square foam tubes for the fuselage. In cases where the fuselage is not a 2" tube, the nose of the plane narrows down to approximately 2". I use 2" as that is the width of a standard FT Firewall. You can easily use this same technique with the 1 1/2" Mighty Mini Firewall or a custom sized firewall of your own construction.
Start by removing any burrs from the edges of the firewall.
The reinforced tape is strong, but a burr can puncture through the tape with the shock created on impact. That could cause the tape to rip.
Next, measure the height of the firewall against the gift card.
Then cut the gift card to the appropriate height.
Cut that piece approximately in half.
Lay out a piece of extreme packing tape. Place the firewall approximately in the center of the tape. You can use more tpae if desired. I have used the tape doubled up and I have used two pieces of tape aligned top to bottom, splitting the the lateral center of the firewall (this gives more tape to fold over at the top and bottom of the firewall).
Align the gift cards at the ends of the firewall, centered top to bottom. Make sure they are standing on end and firmly in the corner. This allows the cards to form the sidewalls after the tape is folded over, without placing extra stress on the card/firewall tape joint.
Trim off the excess tape and fold over the ends and edges.
That gives you a transferable and adjustable firewall.
Clean up the holes covered by the tape and mount your motor.
To use the firewall, set your thrust angles.
Then tape the firewall in place.
Make a quick release tab in one end of the tape.
Finish up by closing up the tape.
Add hot glue as desired to prevent lateral drift.
It helps to finish your fuselage with some sort of tape covering. This will allow the extreme packing tape securing the firewall to be peeled off the plane without damaging the paper.
Here is a relatively short video describing the process.
I hope that you find this helpfull. If you use this technique, plese share your results on the forums and show us your planes.
SP0NZ on March 18, 2016
Great article Tommy! This is an ingenious way to make an adjustable firewall mount to play around with thrust angles. Dead simple and extremely effective.
TEAJR66 on March 19, 2016
Thank you Sponz. I hope others in the community find it helpful.
kkmalu on March 19, 2016
This is simple yet effective technique... Thanks for sharing...
You are welcome.
jrvalentin62 on March 19, 2016
Thanks for the share. Great idea! Like your work. Keep them coming.
You are welcome. There are a few more in the works.
myplane on March 19, 2016
Very nice just one question. I used to get that cross stitched fiber glass tape but can no longer find it.
Can you please tell me where you are finding it.
Thanks, Myplane
I bought that roll from Amazon. http://www.amazon.com/gp/product/B0041PO43Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
That stuff was cheap and it works ok. I prefer Scotch Extreme Packing Tape. You can find that in a lot of different stores and on Amazon as well. It was just a matter of availability at the time of purchase.
Thanks for the info.
Myplane
themajik1 on March 23, 2016
Nice job Tommy!!! That is very simple and appears to be very strong... You might just make a builder out of me yet! LOLOLOL!!!
TEAJR66 on March 23, 2016
Thank you. It is stronger than it needs to be for most foamies. You'll be building before you know it.
Topher76 on March 24, 2016
this is awesome! Thank-you so much for figuring this out for everyone!
TEAJR66 on March 24, 2016
Thank you. You are welcome. Let us know if you use this technique. Post pictures in the forums of your creations.
