Got 2 Dr Mad EDF's Coming 20% More Thust
Dr. Mad Thrust 50mm 10 Blade Alloy EDF 3300kv
Input Voltage: 4S 14.8V lipoly
Rotor Diameter: 50mm 10 Blade
Outer Diameter: 53mm
Weight: 93g with 2mm bullet connectors
Motor: 20-40 Brushless Inrunner 3300kv
Max Amps: 27A
Max Thrust: 650g
Twin Jet Cruzer Speed Build
Jets tape into the nacelles
What about a Twin Jet Cruiser
Love Josh's design hope he doesn't mind if I mess with it a little ? My apologies in advance for using Napoleon units on the drawing :)
Under slunk nacelles would be simpler to engineer I think
Power Options
Hobbyking 50mm Alloy EDF V2 4200kv (4s Version)
Ran these on the thrust rig at the week end they are very well balanced and on the 4S Nano Tech 2200 mAh they push alsmost 600grams a peice
The Hobbyking Alloy EDF series are pre-assembled and dynamically balanced making them simple and easy to fit, no unit assembly is required. As well as high power, these fans have excellent cooling and run so smoothly, the sound is amazing, there is also no housing distortion unlike plastic fans. This nice quality, powerful fan is a great way to upgrade your foamy 50mm jet to a missile in around an hour!
Features:
Pre-assembled
Factory dynamically balanced
High power with superior cooling
High quality construction
Fully servicable
Fast to fit
No housing distortion
Specs:
Rotor Diameter: 50mm 5 Blade
Outer Diameter: 54.5mm
Weight: 85g with 2mm Connectors
Motor: 20-40 Brushless Inrunner 4200kv
Max Amps: 22A
EDF64 with ADH300 Motor Assembled 252W
This unit has the ADH300 motor, producing more power, yet drawing more current.
If your plane can take a larger battery (2200mAh+) then the ADH300 motor would be a suitable option.
Spec.
Test Voltage: 11.1~14.5v (3-4S)
Test Current: 16A
Thrust: 540g
Power: 252W
Motor: ADH300L
Turnigy nano-tech 2200mah 4S 25~50C Lipo Pack
.jpg)
Capacity:2200mAh
Voltage: 4S1P / 4 Cell / 14.8V
Discharge: 25C Constant / 50C Burst
Weight: 239g (including wire, plug & case)
Dimensions: 119x35x32mm
Balance Plug: JST-XH
Discharge Plug: XT60
HobbyKing 30A BlueSeries Brushless Speed Controller
Spec.
Cont. Current: 30A
Burst Current: 40A
Battery: 2-4 Cell Lipo / 5-12 Cell Ni-XX
SBEC: 5V/ 3A Output
Weight: 28g
I have a the twin cruiser twin pack on order, looking at the design I think its simpler to have under slung nacelles
regarding the angle , I'd start with 0 but I would place the aileron on the engine exhaust, that way you will have improved aileron behavior.
since each aileron is connectend to diff servo you can trim each separately.
Do you have any thoughts on fitting thrust tubes inside the nacelles, I saw a post where the guy used paper cups reinforced with packing tape
I have a second EDF unit in the post from HK now
you can reinforce it with some foam if you like., just cut some to size and fit it in.
note that the shorter the exhaust tube is the more thrust you gain.
http://www.youtube.com/watch?feature=player_detailpage&v=qLuydmx9xWs
Thinking about it unlike a real turbine there is no real pressure with an EDF just flow, in the video you can hear the note change with only a few mm of diameter reduction.
Mich be able to find a plastic bottle with the correct diameter for the nacelles which is purely cosmetic.
EDF64 with ADH300 Motor Assembled 252W(4300kv)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6632&aff=652823
Test Current: 16A
Thrust: 540g
Power: 252W
Motor: ADH300L
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22946&aff=652823
Max Amps: 22A
Max Thrust: 550g
