Turnigy 9xr Internal Antenna Mod
by shermanhartman | August 2, 2014 | (9) Posted in How To
How to take advantage of the internal Turnigy 9xr antenna.
I originally got the idea from a thread on the Flite Test forums, but i can't seem to find it now.
The reason i did this mod was because I broke the original antenna on my orange RX module. I was at Flite Fest (which was awesome by the way), I went out to pick up my crashed bloody wonder, and i stepped knee deep into a gopher hole. When i fell, i tried to stabilize myself with the hand that my transmitter was in. Thus, breaking the antenna. This How-to will work as a repair, or as a mod, simply to remove that annoying antenna from the back of your transmitter. This will likely work for most modules that work with the 9xr. Just open up your module and chekc the plug thats connected to the antenna before you buy the pigtail cable.
Lets get started.
The antenna broke of right at the screw base. I figured, rather then trying to fix the broken antenna, fix the problem all together. (Josh Bixler's signiture on the battery door there)
There was a small tab right on the end of the plastic. That broke off, so the antenna doesnt stay in the screw mount anymore.
First, you're going to need to search online for a "RG178 MCX Male Right Angle U.FL IPX Pigtail Cable." I found mine on Ebay, from a US based seller called wifi_expert. I suggest buying from them. Great service and the cable i received is very high quality. I chose the 8" version because i wasn't sure how much cable i would need. I could have chosen the 4" cable and still had enough.
The cable i received along with the Ebay seller's card. Great pricing, fast shipping. I was very happy with my order. Anyway, on to the mod!
Before you start hacking up your module, test fit the plug in the transmitter. Mine fit well, but stuck up higher than expected.
Next, pull your module apart and disconnect the original antenna connector.
Test fit the new connector. Fits perfectly.
Mark out the hole for the antenna plug. The hole needs to be fairly large so that you dont kink the wire when installing it.
I cut the hole out with a Dremel cutting tool, and cleaned up the edges with a file.
Since the wire needs to go around the PCB, you also need to cut a relief in the side of the case so the wire doesn't get pinched between the case and the PCB. Cut using a Dremel tool.
Cleaned up using a file.
Test fitting the antenna plug. Fits without any problems.
I now slid the PCB back into the case, and plugged in the antenna wire. I checked the module to make sure it was working, which it was.
Rather than remove the antenna plug, i decided to leave it, to keep dirt and dust out. Also, so that i don't need to go find it incase i ever want to go back to it.
I simply taped the plug to the inside of the case so it wouldn't cause any shorts inside the module.
You can see the relief working here.
If you got the 8 inch wire like me, coil it up inside the module without making any kinks.
Screw the cover back onto your module, making sure that your bind and change id buttons line up with their respective holes. Make sure to do a range test before you go and fly. The internal antenna has sufficient range for park flying, which was all I needed.
Thanks for reading! I hope this tutorial helped someone get rid of that pesky antenna on the back of their 9xr. If you have any questions, leave them in the comments, I'll do my best to answer them!
rossmort on August 24, 2014
Thanks for the write-up. I knocked this out last night and it worked perfectly today.
shermanhartman on August 25, 2014
I'm glad it worked for somebody else. Did you use the orange RX module or a different one?
wga22 on August 23, 2014
I. Did a mod from RCGroups.com that keeps original antenna, but this one is better.
Thanks!
buckwheat on August 19, 2014
THANK YOU!! I have always wondered what I could do to remove that annoying antenna or how to repair it in case it breaks. BTW if any of u are looking for an awesome/inexpensive transmitter go with the Turnigy 9xr great radio!
shermanhartman on August 19, 2014
You're welcome! its a pretty cheap fix to a common problem. And this is my second transmitter. Before it, i had a CT6B (its a really bad $30 radio), so i dont really have anything to compare to, but the 9xr is a great radio for the price!
bmacw on September 13, 2014
I ordered the cable. But the new orange dsmx module no longer use the blue board in the picture, and the female coax connector for the antenna is soldered to the board directly.
I had to cut the IPX end of the cable I bought (in this guide), and solder the connections to the back side of the antenna posts. It should work (don't have my 9xr yet), but it's not as easy as the tutorial for the new design.
I even returned the first one I ordered, hoping they just had the older stock. But the new one from a different vendor came in the same way.
Just want to make sure those of you buying a new module is aware of this.
https://lh5.googleusercontent.com/-KTrAzs2eFLw/VBTXG69O0iI/AAAAAAAAcHE/umFMSH1yApE/w1593-h897-no/20140913_194522.jpg
shermanhartman on September 13, 2014
How about that. It looks like a completely different board. My module is only about 5 or 6 months old, so they updated the product pretty recently. Thanks for the heads up!
laxgoaltender on August 18, 2014
Nice. Quite informative. I kind of wondered how to do this, but I never thought about it.
jerimiah85 on August 20, 2014
I did the 9dbi mod on my fly sky radio. Now I get 3 miles b4 rth kicks in.
shermanhartman on August 20, 2014
Do you have any info on that? im kind of interested now.
Yeah man shoot me an email boostedlogic@live dot com
shermanhartman on August 21, 2014
Will do when i get home from work.
