Hey Flite Test!
So I recently put together a tricopter using an HXT900 servo for the tail yaw system. I'm using 3/8" poplar arms and 24 gram motors from HK so it's not a big tricopter.
One of the two plywood plates that will sandwich the arms.
I glued the tail boom in place with small block to stop the two forward arms from folding forward.
Then I installed the two forward arms (yellow) with their motors mounts:
Now to the tail servo:
A single metal rod is mounted and secured stationary inside of the rear tail with about 1.25" of the rod sticking straight out the back. Then I took a 1" block of wood and drilled a hole slight bigger than the rod with through. I then mounted the motor on this block and slid the block over the rod so the motor mount can swing freely. Below, the block on the left represent the tail boom, the block on the right is the motor mount.
To the bottom of the motor mount, glue the HXT900 with the gear being vertically in line with the metal bar. I then attached servo arms to the metal bar (with CA) and to the servo. Then I simply bent some metal rod to connect the two. The metal rod is stationary and the servo moves with the motor mount.
It flys really well with the servo set up on the back and I have great yaw-control.
I did take it out for a flight and mid-flight there was so much wind that my forward arms bent back and I crashed, I fixed that with a simple locking system:
So this is the finished product, I used bbq skewers as landing gear, they work quite well and they are easy to replace when the break :)
The battery mount is on the bottom and there is space for a camera in front of the control board :)
Thanks and if you have any questions just comment!
