The Wren ©
by RcFunFlyer | October 6, 2014 | (0) Posted in Projects
Wren
The Wren is an ultra micro RC plane precision laser cut from high-grade 2mm balsa. The Wren has a wingspan of just 20cm therefore it can be taken nearly anywhere you want. It is a two channel aircraft so it has a working throttle and rudder. This makes the Wren a beginner plane to fly as well as a fun plane for advanced flyers. The Wren is very easy to construct.
 SPECIFICATIONS:
  • Wingspan = 200mm
  • Length = 200mm
  • 10g flying weight
  • 3.7v 30mAh li-po battery
  • Up to 10 minutes flight time
  • 2.4 GHz transmitter and receiver
  • Skill level = beginner – intermediate
  • Range = about 100m
KIT
BOX CONTAINES:
  • Precision laser cut parts
  • Two 3mm neodymium magnets
 REQUIRED:
  • Jp Nano stick electronics
  • Jp Nano stick landing gear
  • CA glue (Medium thickness)
If you are intrested in buying the kit, email me at : danielmillsuk@gmail.com
eagle4 on October 7, 2014
cool little model. would be cool if there was a build video to go along with it? or even a flight video. to help people out. that servo on the back looks intersting, is it just an induction coil of wire?
RcFunFlyer on October 8, 2014
Thanks for the feedback offaxis. If you want I could send you the electronics here from the UK to the US with a kit.
offaxis on October 7, 2014
Can you provide more info about the electronics and where to purchase them? US supplier?
I will try to do a flight and build video as soon as I go to the indoor flying hall next.
Hell2Go on October 7, 2014
I too would like more info on this, and a flight video would be great, I'm looking for a small indoor flyer for the winter months in Buffalo. I have a place to fly, just need the right plane to fit the venue. Thankyou for sharing.
The Wren ©
