Here is the project and the video for the scratch built wings out of purple foam. I wanted a long range wing that did not break the bank. Here are the pics that i took durring the build.
This was a scratch built wing mad efom purple foam form the hardware store. I hot wire cut the wings from 3 peices of foam stacked. Same for the body.
I am running.
Orange openLRS 1 watt TX
Orange openLRS 100mw RX
Dragon link RX antenna
MilesRC 1/4 wave 433 UHF antenna
9X with ER9X firmware
9 gram hobbyking metal gear servos
60a Opto ESC
6a UBEC
900mhz 200mw VTX (sucks going to upgrade)
hobby king 900mhz RHCP antennas
Mobius wide angle lense
Propdrive 35-48 900kv with 12x6 folding grumper prop
Will be adding a APM 2.6 FC
wing span 46" or 1168.4mm
2 - 2150mha 4s batterys
The first flight was good needed to put some expo in it and trim. Was a little tail heavy
Added some more weight to it on later flights, it flew like it was on rails. Cant wait to take it out again
Here is a link to the foam board i used. you can make a lot of things from it. I used gorilla glue to glue it together. and it does sand well there is a clear plastic you will take off before you glue or sand but it comes off easy. I wish I had plans but i built it out of my head. but i did put measurements for the wingspan.
for the CG i used. http://fwcg.3dzone.dk/
to make the hot-wire temples for the wings i used this: http://www.rc-soar.com/hardsoft/profilerev.htm
www.homedepot.com/p/Owens-Corning-FOAMULAR-3-4-in-x-4-ft-x-8-ft-R-4-Tongue-and-Groove-Insulating-Sheathing-37L/100320340?N=5yc1vZasbsZ1z0uukr
Hope these links help you to design your own. I wish I had more info.
