specs.
wingspan: 95.5 in (242.5 cm)
overall length: 69.5 in (176.5 cm)
weight (best guess): 8 lbs (3629 g)
power system: two 146g 1460 kv motors swinging 9x6 props 60amp escs and two 2200 3s batteries, 20g metalgear sevos (6)
construction
I began with a wood braced 60 in armin-wing (width of 1ft) then added 17in undercambered wing tips, these give the wing some more dihedral.The fuse is very simple foam-board build with bulk-heads for reinforcement also both the nose and reciver are swapable. Both wings and tail are heavily braced with everything form basswood to birch-ply but are still a bit floppy though not too bad for my first large build. The landing gear consists of two aluminum spars clinging to 5in wheels all held togather with a guitar string and a prayer then mounted to the wing with birch-ply, I bent the wire for the much smaller tail wheel and attached it the same way. It's worth mentioning that I used flip-side foam-board which uses thicker paper but about the same density foam making it heavier than rediboard (the Flite Test stuff). For paint I used a combination of sharpie and spray-enamel.
If you want to know how long this took I'm sorry I have no idea.
It flys !
The Flying
In thick grass lift-off requriers a full-throttle roll of around 40ft. With a 1 to 1 power to weight she climbs like a dream only problem being I can't run wide open for more than 20 seconds without sapping my batteries. Turns are smooth and relaxed the elevator is responsive and the rudder is unnecessary. She will cruise nice n slow at 45% power and climb with elevator at 70% power, a conservitive flight time is around 4 minutes. I don't want to try any aerobatics because of wing -flop but in normal flight this is nothing to worry about. She lands nicely if you flare with a little power just before impact. All in all I'm going to fly this agin and toss a camera into the mix.
below: just crusein
below: I peged the throtal to avoid a patient street-light
below: comin in
