Swappable F4U Corsair (with the FT Powerpod)
First of all I designed the wings.
I creased the foambord and bent it because i wanted to have one piece each wing (not two). I used a wingspar to keep the Corsair Wing in shape. (nearly the same technique as the FT Spitfire).
Then i cut out some wing centerpieces which gives the wings the correct angle and more stability. In the front centerpiece is a hole for my batterypack.
It's an removable wing (the same as the FT Spitfire).
The servos are also at the wing tips.
I designed some fuselage formers which perfectly fits into the Corsair fuselage. Then i used Flite Test's posterboard technique to get the awesome shape.
Flight Video and Canopy are coming soon ;)
If you want the plans i can upload them or i can send it to you, just ask me.
