FTScratchBuild-Advanced
Introducing the FT Spitfire, the 10th installment in the Swappable Series. This build is similar to all of our previous foam board scratch builds with an optional removable wing design.
This scratch build is available as a speed build kit in our store, and the free plans are available below as well!
The speed build kit features a throw gauge and right angle that will assist in the assembly!
The wing on this Supermarine Spitfire swappable has a large under camber wing tip that keeps the plane from tip stalls.
Like some of our previous swappable designs like the Baby Blender, FT Cruiser and FT 3D, the FT Spitfire features a folding fuselage with notches that will help you achieve true proportions and square lines.
Join in the discussion, share your builds and see more photos of this build in our forum post HERE!
FREE Build Plans:
FT Spitfire - Swappable [ FULL SIZE ]
FT Spitfire - Swappable [ TILED ]
Equipment used in this build:
FT Control Horns
Power Pack C
EMAX ES08A II Servo
BLHELI SERIES 30amp ESC
Linkage Stoppers
Push Rods
Can you please supply the shipping dimensions and weight for the single and double kits, so I can try to source alternative shipping?
I know you guys are very busy with vids, builds, manufacture, etc. so if I find a cheaper way to ship and increase your sales I'll definitely share.
Thanks for all your hard work and growing the hobby so successfully.
Cheers.
I live in Auckland. 027 6882828
Thank you FT for expanding the world of RC aircraft in a way never before possible!
Gabe
the battery attaches to the bottom of the power pod which is inserted into the frame of this plane
check out the building of the other swappables and the power pod itself you will get the idea
Thanks for sharing.
I wish they would sell the electronics so I wouldn't have to scour the internet for parts
May amazement was that they would go and share their design even when they have a kits for sale. No other hobby vendor is doing so, or at least I am not aware of another one.
Again, kudos to them, to their lively and humorous, but yet educative videos, and free plans for the folks who want to build planes.
I don't think they will sell electronics at larger scale (at least not anytime soon), because it requires a lot of logistics and space, and much bigger organization. Maybe they will assemble some electronic kits for their setups, which will be nice, since it will remove the doubt of what to purchase for which kit.
Thanks to David and Josh for their advices.
I'm looking forward to testing this legendary aircraft.
Hey Chad, this is your turn to show us how to paint on foam with an airbrush to get a warbird look to our planes. Please, hurry up ;)
Josh, I know you're a passionate but could you talk a little bit slower because it is very difficult to understand everything for a little Frenchie like me :(
http://www.hobbyking.com/hobbyking/store/__16719__NTM_Prop_Drive_28_Series_Accessory_Pack.html
Hope it saves someone some aggravation!
Brad
Don't just trow out a line like "it changes the whole line of dollar tree foamboard ... now they're water proof" and then leave us hanging.
If it locks the paper to the foam and makes it water proof, it would be "the best stuff ever"
Thanks so much!
I wonder what is the final weight of the spitfire ?
Because in France, I can't find exactly the same foam board as you guys... :(
I build the wing and it already weights 135 grams.
For information I use "carton mousse".
Thanks for your answers.
See you !
I have used so called "KAPA" board made in germany or austria. Kapa line is the lightest version, but still 635g/m2 5mm version. I have the final weight with 2200mAh turnigy lipo 3s 850g. I have re-placed the rudder and elevator servos much closer to the CG point, and also lightened up by cutting out some foam from non structural places. I am still thinking to rebuild the plane using 3mm kapa line 570g/m2 or cutting out some holes in structural surfaces than cover the holes with some lighter material. Do somebody knows that, what is the exact weight of the FT spit made from the original material or did somebody built it using depron with coverage? I read that, the original FT spitfire weight is 420g without the battery, but I am not sure whether is it with everything else (powerpod and all the servos)?
Thanks and congrat for the great design for you guys. Attila from Finland.
any Aussies out there having trouble finding cheap foam board?,
Just use 3mm Corflute from Bunnings. $8.90 for a 1200x900 sheet
makes the plane a little bit heavier but not by much.
They ship with a minimum 5 sheet order or you can go in to Fix-a-Frame at 1230 Logan Rd Mt Gravatt, Brisbane QLD 4122.
They have various sizes, I got two 1m x 1.5m sheets of 5mm for $39.
Order kit - check
Order electronics - check
Receive packages - check
Build - in progress
Paint- ??? Hope the link at end of build video becomes real....
Keep up all the hard work guys! We love your site and series!
However I find the formatting of the PDFs could be improved. If the PDF was structured with the size of the foam board in mind it would be helpful. I.E. 1 sheet of the PDF equaled 1 foam board. They could still be tiled, but it would be much more user friendly to do the layout from the plans.
http://www.youtube.com/watch?v=_BykhaR4LEs
Does anybody know how thick the foam should be? Do I have to use 6 or 3 mm Depron?
Great shows, i love your vid's. I'm very happy with my bixler 2 but what your doing with the foamboard is even more fun., or so it seems.
I' want to built a spitfire but run into the folowing: what size of paper are used for the plans and what size of foamboard is required? 3 or 5 mm and A3 size board's? I would have ordered the speedkit for the first build but shipping to the netherlands is more expensive than the kit it selve so a scratchbuild is beter. But i can't find these references so please help.
Keep having fun at what you do, so we can to!
Greetings,
Gijs
My respect for you
Don
I'm having a problem opening the pdf plans, I get a message in Adobe saying that the file is damaged and could not be repaired... Am I missing a trick here?
Regards
Andrew
Here's the 3rd flight video and the first FPV from a MUVI cam mounted in the cockpit.
1st FPV: https://www.youtube.com/watch?v=WdtUs35a86k
3rd Ground View: https://www.youtube.com/watch?v=2BAHjR9j34k
looks like code. I am n00b and the motor, specs, prop, weight, ESC, zippy and blue is way above my pay grade. :-)
Thanks, Scott aka Miggy
"... and yes I did lose a few brain cells in the 60's, and yes, I saw Jimi play live.."
https://drive.google.com/file/d/0B60uA7a-uRTacjlBVGxJbEpvZHM/edit?usp=sharing
https://drive.google.com/file/d/0B60uA7a-uRTaLW9kN1JFZlYzRG8/edit?usp=sharing
FT rules. Love these guys.
Any chance you could throw up a link to the 2.25 spinner used?
Thanks a bunch!...will be doing another!
I just joined, I was puzzled to Dowland image plane where because I want to make
So far I have been through three batteries and have not had a single problem, even with some wind and at 8100 ft altitude. The FT team has really outdone themselves with this addition to the hanger. Well, batteries are charged, tome to get airborne again.
Thank you guys for a great plane.
Cheers, Rod.
On the fist day, the plane flew great with the first 2 batteries, but I wanted to do "ONE MORE" flight. On landing I missed the parked trailer and the tree, but caught the right wing mid way on a light pole. The wing ripped out of the fuse(as its a tight fit), causing more damage to the fuse than the wing. Wing was fine (dented), but the fuse, needed gift card reinforcements and hot glue to fix it, but it still flies GREAT!!!
also does any of you recommend Turnigy Turbo Spinner (51mm) Black for it? Thanks in advance.
the problem is its not taking off even after running 50m.
any advice??
I can't seem to open the full version PDF, the tiled works fine, tho.
Also, I have a laser cutter, but I've been advised to avoid cutting foam board as the material is known to be damaging to the laser lens, could you guys confirm this?
Thanks!
thx
I want to move on and make the Spitfire....
Now, can someone please explain why the wings on these foam board planes do not have a smooth camber over the top of the wing. The construction method consists of a couple of scored lines which results in 3 flats that constitute the upper part of the wing. There is a method shown of how to make a smooth symmetrical wing. Is it possible use this just on the top of the wing and have the bottom flat. I thinking that the Spitfire would look that tiny bit better with a curved upper wing surface.
Thoughts and ideas please.
I buld plan do emax2213 935kv or sunnsky 2212 -13- 980 kv will work for thes plan .my plan with batrry 800g .
sorry for my langu...
link where is that model? Thanks
desthy here from the Philippines. so sad that your kits are not available here in our country but nonetheless, many of my buddies build your planes using our local foambard, hand cut and really flies well. I myself have your ft3d, se5, mini scout and the ft scout.. I plan to add your spitfire in my hangar coz I saw the video and it looks and flies nice. Just a couple of questions though, what is the wing area of the plane, and the recommended auw? I plan to use 1500mah 3s pack, 2216 1100kv motor driving a gws hyper drive 10x6prop and planning to keep the plane under 700g. thanks!
