The wind was gusting to 17mph, hardly the kind of weather you maiden a new design in. But, no guts, no glory. She got off the ground ok but the plane seemed to want to dive on me. I trimmed in some up elevator and got it to level off nicely. That was the only trim I had to give it. Roll rates were nice, perhaps a little fast for a warbird but close. Since I was concerned that the plane was nose heavy I tried some inverted flight. I had to give it some elevator but not nearly as much as I expected. It actually felt about right. It was getting pretty cold so I came in for a landing. I didn't have enough power and accidentally landed in the snow. The landing gear I put on was something I had cooked up real quick because I wasn't going to maiden a prototype hand launching in 17mph wind. I really only expected the gear to hold up for takeoff and maybe a landing or two. It turned out to be far stronger than I anticipated. The gear and plane showed no damage in the impact with the snow. Since it's proven it's self strong enough this landing gear design will be in the final plans. All together the plane handled well and even cut through the wind better than expected.
I have already made several design changes and will be building the second prototype in the coming weeks. I am also working on a canopy. Considering how well the maiden flight went I hope to have it perfected and plans released before too long.
I realize the front of the fuse is a bit off. My glue wasn't hot enough and it cured before I got it set right. This will be fixed on prototype two.
Very nice looking plane btw! Looking forward for the plans :)
1300mah3s battery 8x6 prop. I do plan to try some other motors too. I found on a later flight the diving was because of being nose heavy. prototype 2 is almost finished hopefully I'll get some video.
If you have not tried heat shrinking a 2 liter bottle for the canopy you might give it a try, I found the how to video on youtube and it worked great for me. Now you have made me want to try a war bird.
I started a thread in the forum so people can follow my progress more closely and discuss construction ideas http://forum.flitetest.com/showthread.php?3751-BF-109-Swapperschmidt&p=44793#post44793
Keep up the great work!!!!!!!!!!!
Awesome Plane!
