I wanted to see if I could use a split elevon and some serious mixing to use a split elevon as an airbrake for my flying wing.
Worked great! I'm planning on using something similar on my larger, heavier Raptor 140B and new Raptor 140C. These two airplanes are much heavier and suffer from a very long glide ratio and high speed stall, meaning a very long approach.
Have you tried this before? Anything I could to make it better?
Thanks!
i a currently waiting for servos for it
Oh, and finish driving home next time before you finish your video!
NAM
Have you considered using one of the multiposition switches on your 9x to progressively engage the air brake mixing? I suspect that might help with the sudden bucking you're getting when you flip it on - step down your air speed a bit at a time so you don't suddenly have control surfaces hitting the airflow all at once.
I had programmed something similar for my Bixler. A switch would trim both ailerons up to dump some lift and trim the elevator slightly down to keep the nose attitude right. Each stepping of the switch would increase the amount of trim added. Takes some playing around to get the mix right, but it definitely helped with the never-ending glide problem. :)
