First I have to say special thanks to rcspaceflight, SnowRocker88, nevenelestate, and all the other people in the FT Forum for all the inspiration and to Flite Test for the skills that I have learned by building their airplanes!
Here is my version of the famous TaleSpin Sea Duck!
My Sea Duck prototype has a 900mm wingspan, differential thrust, and one inside elevator to reduce weight.
Look how she flies:
It took a few months to plan, build, and test this plane.
If you want to build your own Sea Duck, download the plans!
If you want to build your own Sea Duck, load the plan!
DOWNLOAD FREE PLAN
You can build this plane in different variants:
AILERONS | 1 INSIDE ELEVATOR | NO RUDDER (SERVO x 3)
AILERONS | 2 OUTSIDE ELEVATORS | NO RUDDER (SERVO x 4)
AILERONS | 1 INSIDE ELEVATOR | 2 RUDDER (SERVO x 4 OR 5)
AILERONS | 2 OUTSIDE ELEVATORS | RUDDER (SERVO x 5 OR 6)
AIRCRAFT SPECIFICATIONS:
LENGTH: 795mm | 31.30 in
WINGSPAN: 900mm | 35.43 in
CG: 22mm | 0.87 in
RECOMMENDED EQUIPMENT:
SERVO (max. 6): 4.4g (TGY-1440A)
MOTOR (x2): DYS 1806, 2300 kv
ESC (x2): 12 amp
PROP (x2): 5 X 3 (5030) 1 x CW & 1 x CCW
BATTERY: 1300mAh 3S (minimum)
WEIGHT W/O BATTERY:
max. 600g | 21.16 oz
You can use your existing Mini Power Pods (for example from the FT Mini Guinea) with the Sea Duck Adapter. Here are some pictures of the adapter:
Have fun! :-)
nice job Gonna build me one of those
Best!
So I have to ask what material were the plans designed for?
