RotorX Atom V3 Build
by FliteTest | March 8, 2017 | (0) Posted in How To
Not only are we impressed by the power in the Atom V3 racing quad, but we’re also impressed with how fun it is to fly and how easy it is to build from scratch. You can build it in less than 20 minutes. All you need other than the proper tools is basic soldering skills. (Watch video for more detailed instructions)
Tools you’ll need
  • 2mm and 1.5mm hex driver
  • Solder
  • Soldering iron
  • Heat gun
  • Wire snips
  • Wire strippers
  • Loctite
First, solder the XT30 power cable on the base layer
Next, select your antenna and connect. Note: DO NOT power on without the antenna being in place because it can damage the VTX.
Attach the plastic base plate to the cube. This part helps protect from carbon and prevents shortages. To attach, use two short, flat screws in recessed holes to secure. Screw the positive nuts on the cube—they are marked with “+”. Then place double-sided tape on the bottom of the cube. This isolates the screws from the frame.
Use two plastic screws to secure the cube to the from into the “-“ nuts. Make sure you secure them firmly.
Tin the ESC solder pods.
Extend wires on motors. (Watch video)
Connect wires on front of quad
Attach motors to the frame with the longest screws and use Loctite.
Install receiver. As long as it fits under the canopy, anything goes. (Including: PPM, SBUS, Spektrum) There are three pads to solder to if your RX doesn’t plug in properly.
Attach the camera. It has three different mounts (15, 30 and 45 degrees). Only permanently glue in if you don’t want to change the tilt. Note: hot glue is a good option to use because it’s less permanent.
Plug camera into front left bottom plug.
Use long M3x12 screws to hold the camera in.
Install LED and route antennas.
Install canopy.
Ensure the wires aren’t pinched.
Route antenna.
Plug in USB and connect to BetaFlight. Plug in battery. Go to motor tab and test motor direction. If your motors aren’t correct, you can check in BLHELI.
Bind and configure the Atom V3.
Set-up switches and configure end points to the DX6.
To enter the OSD turn on quad and radio. Hold left on the yaw axis and count down. Navigate up and down with the pitch. Confirm with roll axis, which goes back or exits out of the configuration.
Install propellers--AND FLY!
Get your own Atom V3 here!!
Anyone out there have the Atom V3 yet? What are your thoughts and favorite flight moments with it? Share them with us in the comments below!
