Rotary drive system for aerilons or flaps
by rick_harriss | September 12, 2014 | (13) Posted in How To
This is not my invention but something I came across on the Tube.
I can't do better then offer the YOUTUBE video that shows it working and some drawings I have made to show how it works.
The idea, like many good ideas is very simple. It creates an aerilon or flap actuator that doesn't use push rods.
The Stiff wire is bent at 45 Deg at the end and encased with a close fitting plastic lid top and bottom. As the rod is rotated the movement of the bent end is transmitted to the aerilon. This allows the aerilon servo to be embedded in the wing and the mechanism totally hidden enhancing scale reality.
tommcgarry on September 14, 2014
Very nice, I've never seen this method before, I'm egar to try it on my next build
Yogenh on October 8, 2014
It looks great. What type servo would you use? Wouldn't it have to be a good and strong one? Really would like to know that kind of stuff. Thanks
rick_harriss on October 14, 2014
As yet I havn't built this but in principle you should be able to use your normal servo. The lining of the box needs to be smooth to reduce friction though.
Yogenh on October 14, 2014
Now was thinking how would you adjust it? If you do use it I hope that you tell use how it worked out. Do you think it would work on a foam board plane?
rick_harriss on October 19, 2014
There isn't any reason to think it won't work on foam. The throw is set by the angle of the bend in the rod and how far the servo rotates.
hotwax on September 12, 2014
If you mount servo and wire at 45 degree angel to the hingeline, you can glue the bend part into the rudder, eleminating all play exept that of the servo itself. Saves time too.
Willsonman on September 12, 2014
Great showing here for those who may not have seen this before. This technique is used a lot in competitive gliders. The idea is that because the components are internal there is less drag. Other scale builders like them because it gives a better scale presence.
