FT Racer Removable Canopy
After flying the FT Spitfire and having to cut a hatch in the underside to make my servo connections, I saw a need for access to the inside of the plane, midway, behind the power pod. This is my solution for the FT Racer.
A nice hole here would be great access to the rear of the power pod. Now for some Canopy Ideas.
This one was easy to build.
This is the type of canopy I'm after, but I don't like the look. I doesn't look "Racer" style. Kinda looks like a middle ages Nun's Habit.
I remembered the two types of canopies available from the FT Racer build video. I liked the slick racer style. I used the one-piece poster board as a template and marked the front and rear position on the plane.
I then created the pieces. These were the final pieces
The Base
The Rear Former
The Middle Former
The Front Formers
After gluing them together, I then put glue down the middle former and placed the canopy poster board on the middle former making sure its centered
I kept it to the front and let it hang over the rear
Then glued the sides
After the glue dried, I trimmed the over hang marking the cut line using the bottom edge as a guide.
An important step is to clean out any glue that has squeezed out into the corners. I also cut the rear of the canopy about a 1/4 inch from the corner to overlap the rear turtle deck when placed on the plane.
Cut the hole for access to the receiver.
Some velcro strategically placed
Another Important step is to cut two pieces of poster board and custom fit them in below the cockpit line, connecting the front and rear turtle decks. I didn't take a picture before I masked and painted. But it's needed to make up the difference from the velcro and clean the lines up overall.
This is it after paint.
And on the plane.
Plans :
