Quadlugs Review
by MESA RC | March 7, 2014 | (12) Posted in Reviews
To the FliteTest Community;
We have been fortunute to land a new sponsorship with owner Danny over at Quadlugs.  They are a new start up business that has brought a new approach to mulitrotor construction hobby.
The new Multi-Rotor experience
 The unique design of Quad Lugs will truly assist you in creating a Multi-Rotor that will fit your needs and requirements as well as building conventional Multi-Rotor craft. The Motor Arm Lugs (patent pending) connect the body framing to the motor arms and as well furnish a receptor for the landing gear. The Motor Arm Lugs also gives the ability to configure the motor arm angles, in 15 degree increments, to achieve  all the conventional set ups as well as your creative own. Not only can you build the multi-rotor of your choice, but finally you will have the ability to disassemble it and re-build it into another. The Motor Arm Lugs are made of reinforced Nylon. Very strong and durable. Our other Lugs - 90 Degree Corner Lugs - Foot Lugs - Body Support Lugs - Motor Mount Lugs - are made of ABS. I am proud to say that all the plastic injection and molds to achieve this, was made and is being manufactured in the USA. The Motor Arm Lugs are being furnish in one color, Black, at this time. However we are working on other colors, to be available in the future. All of the other Lugs are being furnished in Red and White currently, with Blue and Yellow in the works. This really helps in customizing your multi-rotor and orientation. In our 13mm wood series range the Lugs are set up to use 1/2"x !/2" wood, in our Kits we furnish basswood for the motor arms, body framing and landing gear. Other sizes and materials are in the works and coming soon. Now you will have no limits on what you can design and build. Please enjoy and share your designs and builds with us. I hope you have as much enjoyment with Quad Lugs as I have had and continue to have. Please visit our YouTube site Quad Lugs for upcoming Frame Kit build videos, flight videos and more in depth Quad Lugs discussions. This is just the beginning, Be Creative
Quad Lugs are also great for Universities and Research Institutions to build the Multi-Rotor Platforms that are suited for the task at hand. Multi-Rotor's can be designed and then constructed very quickly, with the ability to reuse the Lugs in other upcoming projects. Our Motor Arm Lugs and Adjustable Motor Mount Lugs give a unique ability to the designer to have multiple motor arm degree angles and motor mount degree angles. Truly Unique.
Danny Choate
ps. our Easy-H Copter (which will be available Late February) is the easiest and quickest to build H-Copter around. The frame can be built in less than ten minutes, I have actually put the frame together in FOUR minutes. Of coarse setting up the electronics takes a bit longer. Truly great as a trainer and excellent for trying out new techniques. It's tough!
Patent Pending
Link to their website: quadlugs.com
For more information about the MESArcFF Program: www.mesarcfoamfighters.com
Thanks,
MESArcFF Team
No Comments Yet
Be the first to leave one!
Quadlugs Review
