Power Pod encased in Coroplast
by RobMackenzie | September 29, 2013 | (0) Posted in How To
Last word from me on this subject... promise! If you encase your FT PowerPod in 2mm. coroplast it will be buffalo-hide tough and only weigh 20-25 grams more. I can add 25 grams just going to a slightly larger battery so that seems to be a fair trade-off.
This powerpod has been battle-tested (I "test" crashed it just to be sure) and it survived unscathed. I may start laminating two firewall plywoods together as they seem a bit brittle sometimes right at the edges, or... I could just learn to be a better pilot and stop stressing them so often.
RobMackenzie on October 11, 2013
@DruidDriver: I tried using 4mm without foam and was a bit underwhelmed primarily because of the loss of lateral and longitudinal rigidity... Coroplast alone was very "twisty". IF you were in a situation where you weren't relying on the powerpod to add rigidity, then it would work fine. I explored the options on a video over on YouTube under "Power Pods (and Coroplast)"
Fly'n-V on October 12, 2013
Nicely Done Rob!!! Thanks for sharing!
DruidDriver on October 11, 2013
What about just making power pods out of 4mm coroplast and skip the foam? or does the foam add something special?
