I wanted to see how hard it would be to polyurethane a completed airframe for painting and how hard or easy it would be to slap on a simple paint job.
For any airframe that is geometrically more complex than the Nutball I'd recommend treating the parts before assembly and then painting.
In the video I demonstrate how I:
- Use the same basic technique for poly treating the dollar store foam as my other video
- Mask off a basic two color paint scheme
- Apply the paint and remove the masking
Some portions of the the video are sped up to save time but I wanted to be sure and show all of my steps.
In the end I had a treated swappable airframe that was water resistant with a pleasing paint job.
Time taken:
- 5 minutes to treat and wipe the top
- 5 minutes to treat and wipe the bottom
- 1 hour for the treatment to cure
- 10 minutes to mask off the painted areas
- 10 minutes of spray painting
If you don't count the hour cure time for the treatment I spent about 30 minutes total applying the treatment and painting. If you wanted you could create a much more complex paint scheme with some creative masking and custom designs. Having the poly on the foam core makes the masking tape come up easily without damage.
Have fun.
Minor update: Here is a FT Flyer that I treated prior to assembly and then painted with the same technique
