Painting foam board can be challenging. Here are a few tips for getting the best results when painting your foam board aircraft.
Painting with an aerosol spray paint will work, but be sure to spray on using light coats and you will need to be in a well ventilated area.
Though it's more of an investment, an airbrush is a better option.
A dual-action airbrush will be the best option because it allows you to vary the amount of paint your spray.
We found that the better (more expensive) airbrush paint worked the best for us, because it had more pigment and covered the foam much faster using less coats.
Here's a basic color wheel showing some samples of the colors created by mixing basic prime colors.
When mixing paint, it's good to have more than you need so you can be sure to have consistent colors on your plane. One trick we found that works well is to use old water bottles to mix and store your paint.
We also found that Windex is a good option to thin out your paint. Online sources recommend a 1:1 ratio, but Chad found that a 2:1 ratio seems to work best. (2 parts paint to 1 part Windex)
Another option for sealing the foam board from moister and giving you a better paint surface is to use Minwax.
**Don't use the water-based version. **DISCLAIMER**
HOT GLUE WILL NOT STICK TO MINWAX!
BE SURE TO GLUE YOUR AIRPLANE TOGETHER BEFORE APPLYING MINWAX.
Be sure to alway test any methods or paints on scrap foam. Test methods, paints, and painting styles and find what works best for you... and share it!
The Forum is a great place to join in on the discussion, ask questions and share what you've learned!!
CLICK HERE
Can't wait to order my bat bone, on a side note.
If you do it before assembly (like you show in the video), do you do both sides of the board?
Thanks for all the great airbrush tips, you and your crew are awesome.
Really, these guys create some wonderful teaching videos and you comment is about an typo? Really?
This way it is reusable, you can better mitigate the over spray, and eventually you will get good at using the curves that you make.
Silly putty is a good material to do this with. Roll out a thin rope of putty and lay it down on the underside of the mask, 1/4 to 1/2 inch from the edges. Lightly press the mask into place on the model.
I had trouble in the past with spray paint, I was painting very thin coats but I think I was holding it too close and getting the propellent on the foam paper. (And hadn't heard about the poly)
Can you use a spray on polyurethane vs a brush-on? I hate cleaning brushes.
This site is amazing, I can't believe I didn't find it sooner.
Thanks bunches!
For me, light coat minwax, wipe off excess works very well. Servos got painted the color that was used. I like the cockpit for pilot clear, black or silver... actually my fav is cutting up "Arnold Palmer iced Tea" plastic bottles and put seat, pink pong ball pilot head, helmet, smile and thumbs up. Salute, happy painting
then whether you can give a little tip to choose a paint that is suitable for polygoam aircraft?
advice from you I wait from now on,thank you.
