Has this happened to you?
Gust of wind...or maybe just "plane" bad luck...
Heaven forbid it wasn't the old flying skills just aren't perfected yet, like my case. LOL!
I used to cut and drill my own firewalls for the swappables but I love the FT design and you really can't beat the price (IMHO) for time saved when building. The only issue I've had with laser cut firewalls is that they tend to snap off at the top on those less than perfect landings or dirt naps. Also, they are a bit thin for those "beefier" motors...
I decided to try laminating two of the prefab firewalls with some CA and I have to say...It works great!
(BTW: I don't work for or get a kickback from FT if they sell twice as many prefab firewalls...LOL) Although, i would like to see them sold in an even number pack (4 or 6) for this purpose. Back to the tip....
I lay two firewalls out like sandwich bread...mirrored.
Then add the CA around the perimeter and center like this...
Then fold over the "bread" and clamp...
I love these little Quick Grip clamps...Nope, I dont work for Irwin either...
After clamping, I put a thin bead of CA around the edges like this...
Let the CA cure for a few minutes..per the manufacturer's specs and then remove clamps. I usually let them cure at least an hour after removing clamps.
The PB&J firewall is pretty tough (haven't broken one yet) and gives a bit more wood for the screws to bite into for those "beefier" motors.
Half inch screws get all the way through and protrude a bit but I just give them a blob of hot glue on the sharp ends.
Hopefully this helps someone....and as always, Thanks to the FliteTest crew for all you do to make this hobby a fun and affordable experience! Sr12
Enjoy.
Thanks all for some good points made and info exchange! Sr12
