OrangeRx R615X CPPM
by RCBernDog | June 24, 2014 | (5) Posted in Tips
Single wire connection results in a cleaner build
OrangeRx JR transmitter module on a Turnigy 9X
OrangeRx R615X mounted on a DRQ250
First step go to receiver test
Here you'll see if the channels/inputs are correct
If not go to CPPM settings
These are the channel settings that work the OrangeRx transmitter module and receiver.
What is CPPM?
Combined Pulse Position Modulation (single line connection)
OrangeRx R615X:
http://www.hobbyking.com/hobbyking/store/__46632__OrangeRx_R615X_Spektrum_JR_DSM2_DSMX_Compatible_6Ch_2_4GHz_Receiver_w_CPPM.html
Need help flashing your KK board:
Board: HobbyKing KK2.0
USBasp:
http://www.hobbyking.com/hobbyking/store/__27990__USBasp_AVR_Programming_Device_for_ATMEL_proccessors.html
http://www.ebay.com/itm/like/221461143051?lpid=82
KKMulticopter Flashtool:
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Thank you and enjoy!
RCBernDog
RCBernDog on August 28, 2014
Yes CPPM makes for clean build. Glad it helped.
rossmort on August 24, 2014
One thing to note - In my version of firmware on KK2.1 (Not sure on version, but was whatever it came with when it when 2.1 was first released), I had to enable CPPM on one of the other screens. Something to check in case you aren't getting a signal on more than 1 channel. Thanks again for this write-up. Using CPPM cleaned up my build immensely.
rossmort on August 23, 2014
Wow - I feel quite silly that I have this receive on my Batbone and didn't realize I could do this! It will make things look so much better. Thanks!
RCBernDog on August 24, 2014
Glad it helped
enivid on August 24, 2014
Do we know all of the FCs that are compatible with CPPM?
KK, Naze32, CC3D, Pixhawk...etc
festaman on April 3, 2015
When using CPPM how do you bind the RX since your powering it from the Bind port.
camading625 on November 10, 2015
I have a kk2 board and an orange r615x I powered and bound the receiver by powering the throttle first, binding, and then switching to the bind slot for cppm
OrangeRx R615X CPPM
