Nobody's Perfect! Inspiring through failure....
by alibopo | January 24, 2014 | (5) Posted in Tips
My ‘Einstein’ planes.
I call these my Einstein planes – not because they’re brilliant models, just the opposite - these are the ones I’ve never managed to get flying.
No 1 in the hall of shame – the pusher biplane.
When I started building in foam I tried to create a pusher biplane. I took the rough proportions from an Airco DH 2 drawing and started to work out my sizes. The length of the BBQ skewers that make up the rear boom structure dictated the scale, producing a wingspan of 480mm (just under 19 inches). I also moved the horizontal stabiliser to the bottom of the frame to make running the pushrods easier. There’s really not much to it, and the model came together quite quickly.
Vertical struts were made from popsicle sticks. I added dihedral for stability and undercamber for lift.
I made up little triangular plates to terminate the skewers and link to the horizontal and vertical stabiliser.
This picture shows the bottom triangle and the tail skid
The pushrods pass through fairleads made from gift card plastic.
The motor is a 1300kv HexTronik 24gram Brushless Outrunner, and the prop an 8x4 slow fly cut down to 6 inches. Plenty of power for the weight of the airframe.
The little box fuselage located on the wing with elastics and skewers.
So what went wrong?
For a start, hand-launching it was a problem, and it would only taxi in very short grass or a hard surface. So getting it in the air proved difficult. And basically, the plane was just too fragile to cope with any abuse. I had a good few ‘maiden outings’ hoping for that first successful flight that would allow me enough time in the air to get the little beast trimmed out. But the flights were always short and frantic – ending in a nose-plant or rough nose-over. Something always got broken. I think the plane could have flown, but I eventually I accepted defeat and gave up. I might revisit the idea someday, but it would definitely be with a larger and slower-flying version.
No 2 in the hall of shame – the Pilatus Porter
A set of plans for a free-flight balsa model downloaded from the OUTERZONE website got me going on this project. I printed out a tiled copy of the plans, transferred the outlines of the fuselage shape to foam board, added some corner joins and cut it all out. As you can see it all went together rather well…
The Porter has a very narrow nose, which excludes the use of a power pod, so the engine was mounted on a butt-jointed firewall. The suspension struts are mounted on strips of 6mm MDF glued inside the cockpit area. The motor is a 2200KV which works well with the small prop on the plane. It’s a bit oversized in terms of power output, but I reasoned I would just go light on the throttle.
I was going to install separate wing servos for the ailerons, then decided just to go with a single centrally mounted servo operating the ailerons through control rods and levers….
…you can see the aileron control rod emerging from the fuselage, running along the wing and into  the ‘bell crank’ lever. This lever turns the motion through a right angle to operate the ailerons.
The wing was a basic Armin construction but I added a couple of mounting points for the wing braces. These are servo arms with a skewer through the end to stop them pulling through the wing – I’ve used the same design in two successive builds; the Velie Monocoupe and the AVRO 539B. These wing braces are control-rod wire with a length of skewer alongside, all held together by heat shrink.
Here you can see the inboard ends of the wing struts locating on the fuselage. Both ends of the struts have modified Z-bends, which makes it easy to fit and remove the wing. I used control horns at the inboard end, which are screwed onto an internal pad of MDF.
The undercarriage swinging arms are hinged on zip ties with a small MDF pad creating a hard base - this is also glued to the larger internal MDF pad.
This combining of wood and foam board appears again in my Velie Monocoupe. Selective use of wood gives strength where it is needed, and joins well with the foam board.
The vertical and horizontal stabilizers were fairly simple, but to get the look of the overlapping elevator and rudder I reinforced the fragile foam projections with skewers. I also used a glue method for rounding the edges of the foamboard. (Nothing like as successful as the hot iron system tyoho demonstrated in his “HOT tip, iron your edges” article, but I did go on to use the technique on my first Tribewt.)
The steerable tail wheel was made up from wire and a length of cotton bud shaft glued and taped onto the end of the fuselage. This was the start of my simple tail steering system that I now use on all my models. I wound up a little spring and bent the wire to tuck the wheel beneath the fuselage - just like the real thing. I bent the steering/tiller lever to project on the opposite side of the centreline to the rudder control horn...
…and this allowed the rudder servo to operate both rudder and tail wheel using two separate control rods. I put the steering control rod further out on the servo arm so it turns the wheel more than the rudder. This gave great manoeuvrability on the ground. At the front of the opening  you get a clear view of the two MDF pads that the top suspension mounting lugs are screwed into.
The suspension struts were made using bits of lego! I later scrapped the whole assembly to reduce weight and went back to a simple wire undercarriage.
I wanted ‘proper’ flaps on the wing. The flap hinges are a combination of servo arms and control horns. As it was such a narrow flap I added a skewer reinforcement along its leading edge.
I really liked the way the flaps deployed, but of course I’ve still to see them perform.
I added a little nose piece made from foam board – I stripped the paper from one side to allow the tight curve over the top. The nose hatch is made from shaped polystyrene. I now find myself inspecting all types of packaging before putting it in the recycling bin to see if it might have a build application :)
So, did it ever fly? The short answer – no! This is was what I would call a red-face-flyer. I broke so many props trying to get it in the air it was getting silly. I have revisited it a few times, and worked on the balance and overall weight. In theory it’s ready to go again – but with so many reliable planes in my ‘fleet’ I’m not that enthusiastic.
I think size and weight have been an issue – a bigger scale plane would be more docile and easier to fly. The narrow chord on the wing probably made getting the CG right more critical, though I recently ran the numbers through a CG calculator and came up with a surprising 35% of chord for the CG – I’d always placed it much further forward.
Wing loading comes in at just over 16 ozs/ sq. ft. which (in terms of flight characteristics) puts it on the border between a trainer and a sport model. It all sounds good, but I’ve never managed to get it to fly. Skill level definitely comes into the discussion – a more experienced flyer might keep it in the air long enough to get the trim sorted.
If it doesn’t work next time out I’ll probably go for a major remodelling with more wing area and bigger control surfaces. That may sound drastic but both these builds have allowed me to develop a whole range of strategies and techniques for working in foam board, so I don’t see them as failures. If you’ve had a similar experience with a build, don’t think of it as failure -  just another part of the journey to success.
And why my Einstein planes? These are his words;
“A person who never made a mistake never tried anything new.”
Cheers, and happy building.
UPDATE - The Porter flys! Follow the link at the bottom.
Wing loading calcs; http://www.flyingsites.co.uk/downloads/wingloadcalc.htm
CG calcs; http://chrusion.com/BJ7/SuperCalc7.html
For more inspiration - follow the Flite Test links below to see some of my successful scratch builds.
Dontarose on January 29, 2014
There are lots of really neat features you built into these airplanes. Please don't let the designs die. I personally like the idea of a pusher biplane. I am actually curious if there has been an EDF biplane.
NoUsername on January 25, 2014
Great Imagnation!
808aerosquadron on January 24, 2014
Alibopo, I hope the DH2 project gets a second chance. That would look fantastic in the air.
alibopo on January 24, 2014
Hi, yep, it would look great in the air... :) I've been looking at longer BBQ skewers to scale-up the model - the ones I used in this build were about 10 inches long. I think they also come in 14 inch lengths, which would increase the scale and take the wingspan up to about 26 inches. That would create a lot more lift for not that much more weight. To look right it needs the weight kept way down so that it would float through the air. It's always a possibility.
sailorJohn on January 28, 2014
I also liked your dh-2
Art on January 31, 2014
Nice work - I like the DH2 - don't give up on it or pushers - think De Havilland Vampire with a pusher prop:) Sadly I haven't made much progress on my Nieuport but the DH2 is another one I really like.
alibopo on February 1, 2014
Hi - I did buy some longer skewers the other day... we'll see where it goes. Thanks for the comments.
Naloxon3 on January 25, 2014
Nice design on second plane.. Don't give up on the plane. I'm not an expert but It will fly... check your weight on the plane. Get your CG correct..30% is a good place to start but my last plane is 23% so make sure. Make sure you have enough thrust on your motor.. don't worry about speed. It looks like a trainer. Wing span looks good. Add dihedral to your wing. You will get more lift from take-off. I build 3 planes before I succeeded. My last failed plane was a FT-duster... Made it scale..increase the wing area... it was a sweet plane.. take-off was easy..boom and it was in the air..mmmm got the CG incorrect...tail heavy... lost the plane in a bad crush.. tail between the legs... next day I build a new plane and it fly's awesome.. Don't give up.. that's how we learn..that's how we get better in the hobby we love
joyster on June 22, 2014
+1 on the DH2 - I can imagine that one wafting along on a summer's evening...
Acheronus on July 17, 2019
Keep it up! I designed a DH.2 / Vickers FB5 Gunbus mashup that Josh Bixler flew at FF19!
So it is possible!
