My Homemade FT Spitfire RC plane made from Correx.
by Snoopw111 | October 9, 2013 | (8) Posted in Projects
My Homemade FT Spitfire,made out of correx, always love war birds, I decided to build my first plane , for my first build I do think it came out well.
Built using plans from www.flitetest.com with a few changes. This is my first plane build, and I do think it fly's well, Thanks to:- flitetest.com
alibopo on October 11, 2013
Full marks to the pilot on a windy day! :) It looked a bit tail heavy in flight (really obvious at the 10-15 second point in the video) - maybe push the battery forward a little, or stick a big blob of bluetack in the front of the power pod, you'll find it makes a big difference both to the handling and its ability to punch through the wind. Great build though!
Snoopw111 on October 14, 2013
Thanks alibopo, I did use a small battery on this flight and did not check the CG so you may be right, I need to remember to check the CG on each flight, I have also change my prop to a 10x6 and she fly's even better now, I find the elevator a bit twitchy, need to work on that.
alibopo on October 14, 2013
Couldn't see what transmitter you had, but when I first started out I had simple Hobby King one that only had signal reversing and no dual rates. All my throw adjustment had to be made on the servo and control horns. It was a bit of a pain so I got a DX6i when I started building more planes - that has throw adjustment on the transmitter. I'm getting the hang of it now but I can still panic and over-control if things get hairy - so I start with small throws on any new build. You looked like you were well in control in the clip, but I find it takes some of the pleasure out of the flying if the plane is too responsive.
Mabbs on November 6, 2013
GR8 Job Snoop 10 out of 10 with that high wind . As for your radio there is only one set for me now and that's the Fr-Sky Taranis at £130.00 ish it's stunning and my £400+ Evo 9 is now redundant (don't tell the Mrs) lol
chlguy on April 29, 2014
Correx, huh? Very nice. I wondered about using coroplast, but thought weight might be an issue. Guess you proved it to be a good medium. Curious, what did you do with the edges, did you fill the holes, and also, your score cuts, how did you do your bevels? A build video on using this as opposed to depron or dollar-tree board would be very nice.
Great job. :-)
Yogenh on May 23, 2014
I too would like to know how you worked with it. Did you just do it just like the foam board and was it harder to work with?
You did a great job with it. Keep it going.
