My F-35 VTOL attempt!
by tomstanton | December 2, 2016 | (5) Posted in Projects
The F-35 is an engineering marvel...but how hard can it be to replicate using hobby grade remote control plane/multicopter technology?
The video above pretty much explains all the details of the project, however, I thought I'd share some extra information and images.
So this was the very first prototype test rig which was shown in the first few clips of the aircraft flipping over.
This test rig never actually flew, in fact the test rig that flew in the video was a slightly modified version. The reason why this test rig never flew was due to the aluminium motor mounts (as seen below) which bent around the motors. I believe the motor mounts replicated something called Lenz's Law. But basically, the motors wouldn't spin smooth, or in some cases, not spin at all (just judder as if one wire was loose). Insulating the motor from the bracket with tape and cable ties allowed the motor to spin, but it wasn't ideal.
So I rebuilt the mounts from fibre glass sheet and wood.
The image shown above is of the rear motor. This mechanism would rotate the motor downwards during transition to a hover. It would also allow the motor to rotate on the roll axis for roll control when hovering. The following image is of the rear motor in hover mode.
 After this point, I seem to be lacking in images, please refer to the video to view the stages between.
The following images are of the profile fuselage that managed to acheive a hover.
Specification of the setup:
Motors - Turnigy D2826-6 2200kv
Escs - Hobbyking 40A
Props - 6x4.5 APC
Hover control servos - Hobbyking 939MG
Transition servo - BMS-630MG
Summary
Although this project didn't succeed like I had hoped, I am still happy with how well it hovered given the technology at the time (filmed in 2014). I reckon with a better flight controller, faster servos, faster ESCs and more powerful 'mini quad' motors, this might be able to work. However, thats a thought for next time I try it!
If you found this project interesting, I would really appreciate it if you could take the time to have a look at some of my other VTOL projects on my youtube channel www.youtube.com/user/tomstanton282
Thanks
kmasterson321 on January 2, 2017
How bout using micro helicopter motors on the wingtips - lightweight and probably just enough power to counter rolls?
linz27 on December 7, 2016
Very interesting, thank you
insomaniac45 on December 18, 2016
This is almost impossible without a 3rd motor to counterbalance. (like a tricopter) you could have success with this, but each side needs to be perfectly balanced, You may have some luck counter rotating the props as well, so they are not both spinning the same way, (like a chinook) but also putting the motors above the centre of mass will also play a big part,
At the moment you are trying to balance a pyramid upside down, putting the motors above the weight will allow gravity to assist you :)
Keep up the good work :)
Paulshort on December 13, 2016
Mabye some dihedral on the wing would have helped?
HilldaFlyer on March 5, 2017
Thanks for sharing this attempt. Interesting approach and what a learning experience. I think all adventures should be shared, even if they weren't as successful as we thought they should be. I learned from your attempts, and laughed a lot. I should probably put together a crash reel too.
