Mobius Actioncam Vibration Damper Tutorial
by gsantos_92 | March 25, 2014 | (0) Posted in How To
Hello everyone!
The jello it's a common problem that many have with Mobius mounted on Multirotors. For solve that issue I made a simple vibration damper that solves the problem very well. This kind of vibration dampers are used also in industry and they work very well to RC and you will see ;)
All you need to build the isolator :
-Wood (Two plates 45x45mm)
-Bolts
-Nuts
-Washers
-Steel cable (I used 1mm)
-Rubber Bands
-Cable Fixer
-Foam
On next video you will how was before to use this, and after :popcorn:
And for results even better I made this update to my previous video and the results are even better!
Hope you enjoy this simple techniques and also build some vibrations dampers if you need them ;)
Thanks,
Gonçalo
CarbonAddict on August 12, 2014
I've been using foam ear plugs sandwiched between 2 plates and held together with rubber bands. It seems to do the same thing.
drifter on August 10, 2014
Not clear what you have changed, is it just rubber bands position ?
