In this article I will explain how to build an immersive tiny whoop track using blacklights and stuff You can find in a dollar store. I will also give some tips on how to find a good indoor place to use.
This project started as a protest / solution to stupid Swedish prohibition law regarding cameras on drones. Simply two laws that contradict eachother resulted in drone cameras being classed as surveilance cameras. More on this https://www.youtube.com/watch?v=__8jIVljOjM and https://www.youtube.com/watch?v=wDPO-3so3ac
Students Axel, Erik, Melker, Christian, Pontus at Flygakademien and I built this track in 2 days. Thanks to Linsan for the LED light equipment and L.E.C for UV canons .
So I found a venue, actually upstairs from our workshop, It is not big, but enough for a fast 20 second Whoop race track. I started out, actually without having any measures of the venue, with doing a model in sketchup (which only was a start) Here below is the sketchupmodel. I am a beginner sketchup user, bare that in mind.
Sketchup file
The venue can be any small or medium sized conference hall. Usually if it is a conference hall it is not used during weekends. A Concert hall, may be unused during weekdays. The bottom line is that there are many spaces that are empty, and if You have Your secret weapon (a FPV quad and 2 pair of goggles, one for You and one to dazzle the owner of a suitable venue) it should be easy to find a place. If You have an iPad, bookmark one of the eyecandy Dubai championship track videos at night, and maybe this one (https://www.youtube.com/watch?v=n-C4y2SXuUw or this one https://youtu.be/lMyCMinOBYw) to show the venue owner what "look" you are going for. A controversial idea is buying a couple of 15$ micro drones from banggood to "bribe" with... Chance is the owner of a place has a kid. Thats how I scored the LED pars rent free, well ok, not free but only 15$ instead of 100.
Here is a photo of the place before we turned it into a whoop track.
Lacking the resources in ledstrips, I turned to blacklight as a universal "make it glow magically" solution.
Mostly since the alternative, fluorescent blacklight tubes, are too fragile.
The UV canons had a metal mesh guarding the bulb.
Also about 10 LED par lights ADJ TriPAR LED, set to blue, to make sure there was enough UV in the room. There is a UV ledstrip which has quite some punch in it and It might be a good investment. EBAY LINK.
We lasercut some arrows in a very foam-economic layout and used masking tape that we rolled into double sided adhesive tubes to make the arrows stay put.
Here is the illustrator file of the arrows
We used a Pool noodle matress and two bicycle mudguards to build the tunnel. Inside we put LED strips.
Above the tunnel with a whole sheet of fluorescent paper. Thats before we cut it into strips. One thing about blacklight is that after it hits the fluorescent surface, it becomes visible light. So this big sheet actually lightened up the whole place way too much.
These gates were made of standdard 16mm pvc tubes, normally used to install electric wires.
Inside a 2,5m rgb led strip from hobbyking with a rc switch, controlled by a servo tester.
Also 3 wooden boards, about half an inch thick with two 16mm holes as base.
We are now planning on creating some 20 more gates, this time using the cheaper one colour ledstrips. Search for non waterproof 5050 ledstrips on banggood. Not RGB.
This is a bicycle rim without spokes. I used the same kind of string that is used for windowblinders, which I colored by winding it around a Mountain Dew can and sponging it with fluorescent acrylic colour.
The net is weaved the same way you make a dreamcatcher. IF you are skilled, it is possible to fit a tiny whoop in the hole.
The hexagon is just a simple foamboard 10x10cm square tube design.
Here we used also pvc pipe but this time we covered it with selfadhesive green fluorescent paper. Holding the entire construction up are microphone stands.A Fluorescent very stretchy fabric made the diamonds in the middle.
Here I went for the Manic Spider look. Used the same string but this time I made stripes on the string wound on a dew can, resulting in multicoloured string. A good friend in this case is rubberbands. Loop them around string and hook them around the thumbscrews on stands. The microphone stands have lots of places like to fasten it around. Also, ususally where there is a stage, there are microphone stands.
Originally we had a big piece of fluorescent "wrapping paper-ish" stuff that we put on top of the tunnel, but during the second day I decided to cut it up in strips and use them as lane marking lines. That made the whole course even more immersive. Here below You also see a bigger hole below the whoophole. Pun intended.
In the video below You can see how we used a 5.8ghz reciever with video routed through videomapping/projection mapping software MadMapper. This is not easy and I cant really go into the details about how that works. Took me a year to learn ut myself. But if You own a projector and a MacBook or any apple computer with at least two outputs for video/vga (macbook=one is enough, mac-mini = 2 are needed. One for Your monitor and one for projector).
If You are determined to get it working but dont have a mac, I suggest Resolume Arena.
I did one big mistake in the projection setup. The "screen" above finish line is natively fluorescent, thats why the video brightness looks gained up.
You can also simply put a 5.8 reciever connecting on top of the projector hanging from the ceeling, set to the right channel. Make sure that it is a channel used by the pilots. Best tip is making a sign, telling pilots which four frequencies to use and which one is connected to video on projector.
Lastly some wise words. Any company softens in their attitude when You mention doing it for the kids. If you add that this kind of event distracts kids from staring at their bleeping phones, they soften even more. Probably there is a stage and a small concert hall in Your neighborhood. If it is a no budget thing. Instead of Blacklights, use deep blue color gels on ordinary PAR cans. Lasercutting? Search for a makerspace. Or maybe FlitetTest can manufacture some speed build arrow kits. (not ft arrow).
Showing up at a industrial workshop having a lasercutter, with a micro quad, foamboard and passenger-goggles might be an idea too. And give the guys a hell of a ride. They might then help cut some arrows.
Next event is planned first or second weekend in December. A new article with some "daylight" pictures and videos will be written then.
So go on, find a place and turn it into a whooptrack!
Now please replicate, improve and spread blacklight fpv racing ;)
Here are links to cheap led strips.
One color
http://www.banggood.com/5M-SMD-3528-600-LED-WhiteWarm-WhiteRedGreenBlue-LED-Strip-Flexible-Tape-Light-DC-12V-p-1083186.html?rmmds=cart
RGB
http://www.banggood.com/10M-SMD-5050-Non-Waterproof-RGB-600-LED-Strip-Tape-Flexible-Light-44-Keys-IR-Controller-DC12V-p-1094566.html?rmmds=cart
We used rgb beause we had it layin around.
Single color are cheaper and easier.
Waych for the "53% off" sign on banggood products. Ususally it is older (6 months old) product that need to clear out before new stuff can fit in the warehouse.
Also, read the reviews.
de used 300 per 5m leds rgb strips. There are the ones with 600leds. They are overkill for gates byt necessary if lighting a plane
or 40%...
I take pride in eyecandy like this and this one was awesome, I agree.
Check out Laserowski and RadekRambo on youtube. More of my light-art there
