Short Video on how to do flips and rolls with a KK2 quadcopter. I just started doing them my self one day ago. I crashed a bunch trying to figure out the best PI settings and stick scaling settings which i have at the end of the video. I had a hard time finding a good video on youtube on setting up and how to do your first flips, so i made this video. I am not an expert acrobatic pilot so anyone should be able to do flips and rolls as long as you can fly comfortably in Acro Mode with your KK2 Controller. My KK2 is upgraded to the ver 1.6 firmware but i think these settings should work well on ver 1.5 firmware, but i am not sure about ver 1.2 firware that comes on a stock KK2 controller from hobbyking.
I found it easiest to start low, gain attitude, reduce throttle till it stops rising, full aileron (left or right), flip then back on the power quickly do it does not drop too quickly.
rolls use aileron (left or right), flips use elevator (forward or backward)
PI Editor settings
Axis Roll (aileron)
P Gain : 50
P Limit : 100
I Gain :25
I Limit :25
Axis Pitch (Elevator)
P Gain : 50
P Limit : 100
I Gain :25
I Limit :25
Axis Yaw (Rudder)
P Gain : 50
P Limit : 100
I Gain :25
I Limit :25
Stick Scaling
Roll (Ail) :105
Pitch (Ele) : 105
Yaw (rud) : 50
Throttle: 150
Self Level Settings
P Gain :40
P Limit :20
These are not ideal settings, just what i had in my kk2 when i made the video
quad confirguration
Cheap Hobbyking quad frame (dji flamewheel 450 copy
KK2 controller with ver 1.6 firmware
NTM 2826 1200 kv motors
turnigy 9 x 4.7 abs props
Turnigy Plush 25 amp esc
Turnigy 9x transmitter
Turnigy 9x 8C v2 receiver
Turnigy 3S 5000mah 25-35C Lipo Battery
Did you do the flips with self level ON or OFF?
