FT Versa FPV Build Log
by Nightfox7 | October 4, 2013 | (0) Posted in Projects
I started this build log over on RCGroups, and decided since I was finished, I'd post it here.
So, I've been wanting a cheap flying wing to do some proximity FPV with, while not worrying about the airframe. And after looking around at various designs, I decided on the versa wing, designed by Josh Bixler.
Here is the build for this wing, and the plans are towards the bottom of the page. FT Versa Wing Build
The wing will be made out of Dollar Tree foam board, then covered with tape for durability, and water resistance.
My electronics:
Motor: NTM Propdrive 28-26 1200kv
ESC: Plush 25amp
Servos:
HXT900's
Props:
APC 8.4e
Reciever:
Corona RP8D1 9 channel 72Mhz
Battery: 3s 2200-2650mAh
For my FPV system, I will be running 1.2Ghz, with a simple OSD just to monitor battery voltages.
Let's get started! Put some music on, grab a cool drink, and start tiling those plans together!
Then, after that, transfer the plans to your foam.
I cut the wings out! I have the spars to cut, and the winglets, which I'm going to make out of chloroplast (that plastic stuff you make signs out of).
Also, some of you may be wondering why I transferred all the lines of the plan to the foamboard, the reason for this is that I cut my parts out freehand - I don't use a ruler.
P.S. Sorry about my crappy pictures, I keep forgetting to charge my camera battery :o
Okay, got a little free time today, I got a wing put together.
First, I dry fit everything to make sure it all went together right, and it fit perfect.So I went ahead and taped the top and bottom portions of the wing together on their leading edges.
Then, I flipped it over and pre bent everything to establish the creases, and set those creases with some hot glue.
Time for the servos. I glued/ zip-tied the servo on.
After that, I glued the wing all together. Doesn't look too bad to me! Time for the other side.
Now, the waiting on HK begins.
Got the wing put together, and there are a bunch of wires and stuff inside the wing such as an OSD, and power filter, and all the wires that I will be hooking up my camera and stuff to. I also got the top half taped up! :D
Here's my shot at a DIY power filter. A sander style.
Okay! She's done! CG ended up about 1/8th" ~ 1/4" behind the recommended CG. So, we will see how that works out when I get her in the air. She is quite heavy, I don't know the exact weight, but it won't be a floater. The power filter I made works perfectly! full throttle and no lines in my video. I will say this though, with the motor that is currently on it, I feel like it will be quite speedy.
The waiting begins for a free day! :D
Look at her in her glowing orange goodness!
This is where my 1.2GHz VTX lives, topped with a cloverleaf.
And up front is the amazing PZ0420 camera from SecurityCamera2000
It's hard to tell, but I have my antenna running in the inside of my wing, then took a pushrod guide and fed it out the back, then glued the winglets on. This should do a good job of keeping my antenna under control.
And, a home for the battery of course! It almost fits to where that door will close flush, but not quite.
Hopefully you will see a FPV video coming from me soon!
Blue Skies!
-Seth Park AKA Nightfox7
Driveandairsmash on October 9, 2013
My friend has a old ziggy with a built in battery and that battery hatch reminded me of it lol. Good job I like the color of the plane! lol it is Almost Halloween!
InTheFade on October 9, 2013
Pretty sweet! Great build. I love how nice and easy this wing goes together and it looks nice taped up. I had issues with my 2200mah battery fitting. I think i may have to go with a battery tray mounted on top like the zagi's used to have it.
