FT Sportster Build
by FliteTest | November 18, 2015 | (16) Posted in How To
FTScratchBuild
FT SPORTSTER SPECS
  • Weight without battery: 0.95 lb (430 g)
  • Center of Gravity: 2.5 in (63 mm) from leading edge of wing
  • Control Surface Throws: 12 - 16° deflection; Expo 30 %
  • Wingspan: 39 in (990 mm)
  • Recommended Motor: 1000 kV Park 425
  • Recommended Prop: 10 x 4.7 slow fly
  • Recommended ESC: 30 amp minimum
  • Recommended battery: 2200 mAh 3S
  • Recommended Servos: (x4) 9 gram
FT SPORTSTER PLANS
If you've never built our Swappable Power Pod, check out the video below.
STORE LINKS
New to the R/C hobby?
Here's some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get Some Here!
The-One-Who-Never-Crashes on November 19, 2015
Great design and video! Any content coming up on the Monster Balsa Speedster?
Paulshort on November 19, 2015
Would the motor off an old DJI phantom vision 2+ work? is it too low KV?
WombatControl on November 19, 2015
Probably not. The Phantoms run on 2212 motors, which are bigger than the 2204 style motors used for the Mighty Minis. You are right, the KV rating would be too low, and you'd also be significantly nose heavy.
danield on November 19, 2015
What is the blue and white plane in back ground?
It's a Mighty Mini Mustang, I believe.
Lmontanez on November 19, 2015
what about the plan of the mini FT Sportster version?
Based on what Josh said on a recent Periscope, it's coming this Friday.
gmoore on November 20, 2015
Never mind my comment about the plans. I found them. Great Plane looking forward to building one.
Silvio3099 on November 26, 2015
There has been a problem with the link plants. Not being able to download.
PropSpinner on November 20, 2015
Pylon racing at FliteFest.
Phlier on August 18, 2016
This is the first time that i have left a comment on the flight test wall. I had to write a review on this plane because i enjoy flying it more that all of my other 3d or scale planes ranging in sizes from umx to 50 cc. I had watched watched the video of the pylon racing and thought that this would be a great plane to have fun flying in a group with, i was correct. This plane flys really slow and stable despite it feels a bit heavy for its size. I can hover this plane just over half throttle just as easy as my eflight slick. It holds a knife edge and does most of the tricks that i can do on a 3d plane other than the knife edge loop and spin. Great job guys on the design. There is a few things i plan on changing but there is no real need. I would make the control horns a bit longer to get more throws, and get arid of the swappable setup. I built mine from your plans. Thanks for the great plane, and the guys at our local club are all inpressed by the slow aerobatic praditable flight and are planning to build a bunch. Thanks Flight Test
Kroz on September 17, 2018
Can someone tell me the thickness of the foam board? Also the dimensions of the boards, if someone knows. Thanks
uniondelta on October 24, 2018
FT Sportster Build
