FT Mini Scout (High wing) From the Philippines
by Ernesto Bacani | January 20, 2015 | (4) Posted in Projects
I am infatuated with the mighty minis. Super! They are so cute. I am a newbie with RC scratchbuilding and flying. I am just learning a lot with Flitetest together with the RC community here. Really helful people. ;)
 This high wing trainer flies great with 6x4 prop and a 3S battery and 250 size quad motor 2300 KV. Thrust angle is slightly modified since this plane has a much heavier structure and a much greater angle of attack than the mid wing mini scout. Due to the P-factor and torque issues, it has right-down  thrust angle. Slighty lesser in severity from our original mini scout in terms of right thrust but slightly higher in severity in terms of down thrust.
The CG is still the same since I just took the original unique wing of the mini scout. Same measurements to balance the plane.
The control surfaces are unchanged as well but higher throws  are needed due to added weight.
I am very much convinced that the fun part of RC scratch building and flying is the memory that we make on it. The reward is really exponential when you fly what you build together with the important and lovely people around you!
grether2000 on April 27, 2015
A nice variation. Congratulations on a good looking plane. Is that painted, or colored some other way?
awesomebilities on May 10, 2015
Excellent paint job, how did you get it to look that good?
NoUsername on April 27, 2015
Good job on the build. Love the colors on the plane.
winglet on May 6, 2015
Outstanding!
Ernesto Bacani on June 3, 2015
Thank you guys. The plane is not painted. The designs and colors were made out of hard papers only. :)
Dale Vincent Pepito on March 26, 2017
Ganda ng gawa mo boss. San po kau bumili ng mga gamit boss? Gaya ng rx at tx nyan dto sa pinas?
