Delfer version 3
by 81zapper | April 12, 2015 | (8) Posted in Projects
This is a new version of my previous scratch built the Delfer. The overall wing area is smaller and gives it a nice quicker reaction with the ailerons. I wanted to build a plane that was simple to build for a beginner like my self and that was small enough to fly in a small school play ground. This version has a 7.5 prop but I think it needs to be changed to get more bite. I t currently flys real nice and slow if needed. Loops are a bit of a challange as it needs more prop. It only took me about four hours to build from printing plans to flight ready. The video is the maiden. The plane is a little touchy on aileron rolls as it was on high throws unknown to me at the time  .
Here are the plans  all laid out and taped ready for transfer
All the parts are now cut out ready for assembly
Tail assemby complete. (Same assembly as the FT flyer)
All ready , now for the electronics
Servo installation and battery location
All done   Ready for maiden
heres a closer view of the elevator and rudder connections
 The plans are in CAD  format  There should be free software out there to change it to pdf
DXF file format
PDF Delfer 3 tiled
Specs. for this plan are as follows
Motor  24 gram blue wonder  1300kv
600 mah battery
7x5 prop
20 amp esc
9 gram servos
used powerpod from Flight test design
yanto on April 29, 2015
I would like Dowland schematic drawing of this plane, where I could Dowland
81zapper on April 29, 2015
Thanks for your interes
t I have now put a pdf tiled version just above the spec. list hope this helps
Let me know how you make out with the flights
NoUsername on April 27, 2015
Great looking plane! if I make one I would put the landing gears on.
Thanks
Landing gear work great video was just a test flight
FeWolf on May 1, 2015
Very Nice, and thank you for the plans!
81zapper on May 4, 2015
Your welcome enjoy your flights
winglet on June 12, 2015
Recently finished building your Delfer and got it in the air this evening. It is doing great and I am enjoying it. It took a little while to get trimmed out of course, but once it was dialed in; it pretty much flies on rails. I'm using a 3 cell battery and fly it mostly wide open. I don't think this one was designed with slow in mind. Nice easy fun design and build. Thanks for posting your plans.
81zapper on June 12, 2015
Thank you very much for your feedback on my article . Its great to here from others
Trying my design ,especially a successful one . Your right this is a fast plane compared to the first version
Which I still fly today as a relaxing flight. I hope you enjoy it for along time
Once again thank you it is appreciated
Had so much fun with it, just had to make one more flight before dark Zapper. Think I have almost an hour of flight time on it already? I also posted several photos of it in the forums under swappables and other FT designs for you to see. Sharing this stuff makes it so much fun. Just so you know, your design is flying over Kansas.
81zapper on June 21, 2015
Excellent. Glad your having a blast and thank you for making it successful
Saw your article in forums Nice job with your mods you have to stop though your making me blush :) glad you like it I'm having a blast with mine
boysjea on June 8, 2015
Neato
winglet on June 6, 2015
Just printed your plans. Nice work. Looking forward to building one in the next few days.
magicmerlin on August 3, 2016
Interesting looking plane.
Delfer version 3
