Earlier this year, I posted a picture on the Flite Test Facebook page. The picture was a trainer that I designed and built with inspiration from a Cessna 270. While I was maddening it, I flew over a tree, freaked out and there it goes into the tree.
Upon posting the image someone asked if it was a Flite Test model and if it could be used with a FT Power Pod. Unfortunately Flite Test didn't come up with this design, but it is made with Flite Test building techniques. I took it as a challenge to get a Power Pod into the aircraft. Sadly it was too small. So I loaded up Google Sketch Up and modified my design to fit the FT Power Pod.
Here are the plans that I ended up with. (All measurements are in milimeters)
Luckily all the parts fit on one sheet of Dollar Tree foam board(the kind Flite Test use).
Foam board layout.
Front View
Isometric View
Isomeric with dimensions
Side View
Top View
Fuselage Dimensions
Horizontal Stabilizer
Vertical Stabilizer
Main Wing. (Dihedral can be added for stabilization)
A video will be posted as soon as I get one complete!
Thanks and good luck building!
My cessna. RICHGCOOP
RICHGCOOP
RICHGCOOP
Thanks!
