BOUGHT FROM: Hobby Wireless.com
T905 Transmitter 900 MHz 500 mW 900MHz High Sensitvity Receiver HIGH GAIN PATCH ANTENNA 900Mhz 8dBi Nano Microphone w/Volume Control
BOUGHT FROM: Securitycamera2000.com 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera with OSD Menu DNR
BOUGHT FROM: Walmart VIZIO's 19" Class Edge Lit Razor LED™ LCD HDTV
I got the tripod from walmart. Then cut a 1 x 4 inch board drill holesmthen attached the board to the tripod with zipties. Then attached two Screw-In Tool Hangers to hold the monitor, http://www.walmart.com/ip/Lehigh-SH13-25-Screw-In-Tool-Hanger/19870521
http://www.walmart.com/ip/Targus-58-Camera-and-Camcorder-Tripod-TGT-BK58T/16524297
http://www.walmart.com/ip/Vizio-19-Class-LED-LCD-720p-60Hz-HDTV-1.2-ultra-slim-E191VA/20461471
Until then.... This is what I did.
Then cut a 1 x 4 inch board drilled holes for mounting then attached the board to the tripod with zipties.
Reply
Thanks!
I like what you did here and I want yo do the same with a similar TV and build it into a pelican case. I assume the screen has a brightness of 250 nits as most do, it looks like yours is bright enough. I was going to add more leds to my screen to get it a little brighter, do you think that's necessary?
